1g-fe altezza idleing high
Postby DXROLLA » Wed Jan 29, 2014 6:46 pm
My sister has a 1g-fe powered altezza/is200. It is idleing high when in park and stationary at around 2500rpm-3000rpm. Is there any way of running a diagnosis check on it to get a falt code? Or would any one know what it could be?
DXROLLA
Re: 1g-fe altezza idleing high
Postby Rob » Thu Jan 30, 2014 9:35 pm
Is this from cold or once it should be warmed up? It could be the idle air control valve sticking from carbon build up
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Vertigo » Sat Feb 01, 2014 4:34 pm
Im surprised Toyota used the 1G in such a late model vehicle - interesting.
TVIS just kicked in, yo!
Vertigo
Postby RS13 » Sat Feb 01, 2014 10:56 pm
The G-series engines are only 3 years older than the S-series.. the 1S first came out in 1982 over 1979 for the 1G. Did you know they made K-series engines up until 2007? Now THAT is more impressive.. :)
RS13
Postby Grrrrrrr! » Sat Feb 01, 2014 11:08 pm
late k series were all in forktrucks tho right?
Grrrrrrr!
Postby Lloyd » Sun Feb 02, 2014 9:34 am
Nope, Liteaces
Postby Dell'Orto » Sun Feb 02, 2014 9:58 am
And Kijang too!
Users browsing this forum: Google [Bot] and 26 guests
