Mr Ree wrote:I think "2JZGTE" might have bought some of the 3000's for the last track day, and they completely destroyed a set of rotors, so I wouldnt be going near them in a heavy car.
What do you need pads for? Track days only, or for both street and track? It is very difficult to have the best of both worlds when you own a heavy car, as the brakes take an absolute hiding if you want to push hard.
~SlideWays~ wrote:Very different car but I run DS3000's in my AE92 GTZ turbo around 950kg, still with standard single pots and factory discs, but with Motul 600 fluid.
They work very well on the road even from cold and quite well on the track, after half a dozen hard laps the pedal would start to feel soft and a bit less bite but they never stopped working like previous pads. Which is pretty damn good considering the rest of the brakes are standard.
Even in a light car they eat the discs.
The brake dust eats into alloy too by the looks of it.
I'm upgrading to Wilwoods later but have been impressed with DS3000's. I paid around $350 for a front set a few years ago.
cat007 wrote:Thanks
I was using the Mintex 1166 compound on my stock supra brakes a while back. They melted and destroyed themselves after a short period of time. I was running slicks though so that probably didn't help their life span haha.
I didn't find them too dusty or wear too much on the street - on the track though I must've overheated them.
I don't plan on doing long sessions at the track. The idea being I can take the car down to open track days and do a few laps at pace then come into the pits for an hour or so.
Can you get other pads? Like the Ferodo 2500's?
Mr Ree wrote:Is the caliper set up 2/1 on your A70? And what diameter rotors?
By backing plates, I meant dust/stone shields for the rotors. They trap alot of heat.
Is there room for ducting to fit? If so, I would recommend it as anything you can do to help keep temps under control is a good thing.
Bazda wrote:I run the Wilwood Polymatric C pad, dad has used them for years racing.
They last a whole season and dont eat discs. His discs have been on the car for 2 years+.
Bazda wrote:Whats a set of Project Mu pads worth?
I did try Endless pads once, they were real good but ate my discs pretty badly.
How well they bite depends on the pad coefficient. The polymatrix pads come in about 5 different compounds. All depends how your brakes are setup to determine what coefficient you need. I tried the Polymatrix A and all I did was lock wheels as soon as the pedal was touched. The C seems to feel real nice and a lot of our customers also like it.
http://www.wilwood.com/BrakePads/BrakePadsApp.aspx
touge_ae101 wrote:Good pads and braking setups will always chew disc's. Generally it is accepted that for every set of good pads you'll go through 1-2 sets of rotors.
