2jayzgte wrote:I could also improve the rotor I use but I personally think again as stated above.If you have a look at the 60Cuba setup they run dual BMC's with ducting and have very few issue's with the factory rotors as they have dialed more rear end bias on and at 1500kg and 400+ KW car and they have the ability to run all day only suggests to me is what my guys who look after my car have been saying all along that using more rear brake and directing the bias to the back is probably the way foward.
1I1 wrote:2jayzgte wrote:I could also improve the rotor I use but I personally think again as stated above.If you have a look at the 60Cuba setup they run dual BMC's with ducting and have very few issue's with the factory rotors as they have dialed more rear end bias on and at 1500kg and 400+ KW car and they have the ability to run all day only suggests to me is what my guys who look after my car have been saying all along that using more rear brake and directing the bias to the back is probably the way foward.
Have you considered using a more aggressive pad in the back of your Supra Coryn? Did I read somewhere you use the TRD Black rear pads? They are good pads, but it's a lot easier to try a different pad than re-doing brake lines and adding a proportioning valve.
2jayzgte wrote:Been there Mark done that.
Here's the list.
Secondly the 60Cuba Supra have done pretty much the same thing but have a dual BMC setup but it works and they don't kill pads & rotors like I do and basically it all centers on dialing in more rear brake.
I would have done the brake proportioning valve mod ages ago but I don't no if its legal or not for the road.
Mr Ree wrote:You destroyed your front rotors at Taupo, and that was on road tyres.
While the slicks contribute to better braking and more heat, Slicks arent to blame, the brake pads/rotors getting overheated to the point where their wear is accelerated exponentially, is to blame.
Keep everything cool enough, and slicks will be fine.
Mr Ree wrote:What tyres are on it? A brake system is only as strong as the tyres it is wearing
2jayzgte wrote:Mr Ree wrote:You destroyed your front rotors at Taupo, and that was on road tyres.
They are to blame because I'm asking the car's systems to do what they weren't designed to do.
I push the car harder and parts reach there limits accordingly.While we have a head start originally from Toyota I don't think the car was designed to run with that sought of tyre in mind.
Keep them in the correct heat range have a look at the list do you not think I have'nt tried over the years TBH a few times I've thought about throwing in the towel.
But have come to the realisation that at the end of the day my car is a ROAD car not a race car hence why I tried to stay away from race car solutions.
Grrrrrrr! wrote:As a cheap intermediate step.. how about a spare windscreen washer bottle hooked up to the brake lights set up to spray a fine mist of water onto the discs/calipers when on track. Top up the washer bottle between sessions.
Mr Ree wrote:You dont want to spray water directly onto the rotor face.
The best way for all rotor cooling to be achieved is through air, or air and water being forced through the centre of the rotor, so it can pass across all the vanes, to get the most even cooling.
Grrrrrrr! wrote:Mr Ree wrote:You dont want to spray water directly onto the rotor face.
It wont be water once it touches the rotor, it'll instantly vapourise. And if the droplet size is small enough you shouldn't get any noticeable erosion of the rotors. Not that you'd notice compared to the rate he is apparently eating rotors as it is.The best way for all rotor cooling to be achieved is through air, or air and water being forced through the centre of the rotor, so it can pass across all the vanes, to get the most even cooling.
One nozzle per side to keep the cooling even.
Mr Ree wrote:2jayzgte wrote:Mr Ree wrote:You destroyed your front rotors at Taupo, and that was on road tyres.
I know you have tried multiple pad compounds over the years, but clearly, you are still generating too much heat in the system, thus you see the rediculous levels of wear, that keep costing you big $$ every track day to replace rotors etc
The fact is that if you can keep your brake systems heat under control, you wouldnt suffer from the same rotor and pad wear, regardless of brake bias setup.
The way I see it, you have two real choices...a better ducting setup while employing water cooling, or brake bias adjustment.
Both will help alot, but keep in mind that the former is road legal, and the second is'nt.
If you decide you dont want to add the proportioning valve, we should just both build up a kit for water cooled brakes, and not look back
touge_ae101 wrote:Wilwood are now doing a 5-port brake bias adjuster to work with a standard master cylinder and standard lines (I'm assuming supras have two lines running to the rear)
cat007 wrote:2jayzgte wrote:Been there Mark done that.
Here's the list.
Is there a build page for this 60Cuba Supra anywhere? I can't seem to find anything interesting on it except for some youtube videos from a couple of years ago....
