Help!! piston rings for 3sge beams
Postby James Sen » Sat May 17, 2014 9:16 pm
So I'm doing a standard rebuild on 3sge beams motor out of an altezza, I bought a set of genuine toyota piston rings, when i came to put them on the piston i saw that the 2nd ring and the oil ring are to thick and it doesn't fit on the groove. So i checked the the part (13011-88570) and thats the correct one listed for the engine. The pistons in the engine are the factory toyota ones.
So my question is that has anyone else come across this problem, or does anyone have this engine apart to compare the piston ring grooves compared to my ones, maybe theres something weird with my engine or toyota may have packed the wrong rings. can anyone help??
1992 MR2 GTS 353kw@ the wheels on 23psi(pump gas) 11.3@206km/h
1998 Toyota Carina with a GTT caldina 3sgte.
1986 AE86, beams engine 6spd gearbox
James Sen
Re: Help!! piston rings for 3sge beams
Postby Soiled » Mon May 19, 2014 12:43 pm
I have a left over piston in my garage somewhere, will take a photo when I get home tonight.
Soiled
Postby Soiled » Mon May 19, 2014 6:17 pm
Hope that helps.
Soiled
Postby James Sen » Tue May 20, 2014 7:46 pm
hey man thanks for the pic, it does look identical to my piston, do you still have the original rings for it, just need to know if the top ring is the same thickness as the 2nd ring.
James Sen
Postby Soiled » Tue May 20, 2014 9:31 pm
Nah they're long gone sorry :(
Soiled
Postby CAMB01 » Tue May 20, 2014 10:41 pm
Just measure the ring groove in the piston. Order some aftermarket rings with the ring sizes and bore size.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby RomanV » Fri May 23, 2014 7:19 pm
There were two variants of the RWD beams motor for compression ratio, so maybe the Auto motors (11:1) had a different piston ring part number to manual motors (11.5:1)?
I've got some pistons somewhere here you can compare against if need be.
Postby James Sen » Mon May 26, 2014 11:35 pm
yeah thats what I thought at first but theres only one part number listed for the altezza beams engine, yeah if i can get a piston to compare with that will be great.
James Sen
Postby Soiled » Tue May 27, 2014 8:27 am
The 1GFE in the Altezza is also a 'beams' engine... haven't happened to get some 1G rings by mistake??
Soiled
Postby James Sen » Wed May 28, 2014 11:05 pm
its was for a 3sge for sure and plus the rings in the kit was for 4 pistons
James Sen
Postby Bazda » Thu May 29, 2014 3:45 pm
Measure the ring gap on the pistons.
If you put up some measurements people may be able to help a little more.
Postby James Sen » Thu May 29, 2014 10:38 pm
ok the ring layout on my pistons are 1.2 x 1.2 x 3mm and the layout on the toyota genuine rings (which are the ones specified for my engine according to the part numbers) that I bought were 1.2 x 1.5 x 4mm
James Sen
Postby Celica RA45 » Fri Jun 06, 2014 10:51 pm
sounds like gen 3 3sge piston rings
Celica RA45
Postby James Sen » Mon Jun 09, 2014 10:43 pm
which ones? the rings off my piston or the rings that I got
James Sen
Postby Grrrrrrr! » Mon Jun 09, 2014 11:02 pm
1.2/1.5/4 is gen2 & 3 3sge and gen 2,3 & 4 3sgte, prob gen 1 too, but i've never stripped one.
Grrrrrrr!
Postby Celica RA45 » Mon Jun 16, 2014 11:22 pm
take the rings back and ask for another set. sounds like some one has mixed the ring packs up
Celica RA45
