spot lights. gay or not?
Postby 1984FXGT » Sun Aug 24, 2014 6:48 pm
Are spots on a works replica gay or not? I cant decide. What do you all think. (They are not properly secured or aligned yet)
1984FXGT
Re: spot lights. gay or not?
Postby Stott69 » Sun Aug 24, 2014 6:50 pm
Are you night rallying?
Stott69
Postby Al » Sun Aug 24, 2014 6:50 pm
Fit what you want. It is your car, don't build something because of what someone else thinks.
However don't be one of those wankers that drives around when it's getting dark with only their fogs on.
Al
Postby Vertigo » Sun Aug 24, 2014 8:07 pm
Looks good imo.
TVIS just kicked in, yo!
Vertigo
Postby loudstealthGT-Four » Sun Aug 24, 2014 9:23 pm
Would look better with four lights along the top/ between the headlights.
loudstealthGT-Four
Postby ~SlideWays~ » Mon Aug 25, 2014 12:20 pm
Would look cool with some CIBIE covers.
Also not sure how a car becomes gay, they have no penises?
~SlideWays~
Postby 1984FXGT » Mon Aug 25, 2014 12:54 pm
I have some covers for them. Could get some stickers made for them.
1984FXGT
Postby 1984FXGT » Mon Aug 25, 2014 2:04 pm
Would something like this be better, with a wider lower set?
1984FXGT
Postby matt dunn » Mon Aug 25, 2014 7:14 pm
1984FXGT wrote:Would something like this be better, with a wider lower set?
yes
Postby cat007 » Mon Aug 25, 2014 9:51 pm
Al wrote:However don't be one of those wankers that drives around when it's getting dark with only their fogs on.
Crap. I'm guilty of this in my supra. Why is this wankerish?
Postby Al » Mon Aug 25, 2014 10:21 pm
Are the headlights not useful? Do you wish to set yourself apart from other drivers on the road somehow? Do you see fog where there is none? Same applies for park lights, side lights, forward positioning lamps, whatever you want to call them. People switch them on in low light situations. Why not just turn the head lights on? Are they trying to save power?
Al
Postby cat007 » Mon Aug 25, 2014 10:28 pm
Al wrote:Are the headlights not useful? Do you wish to set yourself apart from other drivers on the road somehow? Do you see fog where there is none? Same applies for park lights, side lights, forward positioning lamps, whatever you want to call them. People switch them on in low light situations. Why not just turn the head lights on? Are they trying to save power?
I prefer the look of the mk3 supra without its lights up. And when I don't need lights to see, rather helps me be seen by others, I prefer to keep my main headlights off until I need them.
Why does it make you so grumpy? Lol
Postby Leon » Mon Aug 25, 2014 10:29 pm
I have to admit that I keep thinking about quad lighting the front of my AE92 club car.
Though I'd have to fit two main beam, and two fogs, to keep it legal
Postby GDII » Tue Aug 26, 2014 9:30 am
Legally you are only allowed to use your fog lights in fog and bad weather conditions like very heavy rain.
On another note, now DRLs have to switch off with headlights AND fog lights. It used to be headlights only.
To the OP, I didn't think it was legal to run more than 2 fog lights on the front. They would look better with the bottom set spaced further apart though.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby edwagon » Tue Aug 26, 2014 3:04 pm
I reckon it looks good - especially if you space the bottom two out
my 2c:
- Don't block airflow to the radiator
- Make sure you adjust them so they don't blind people. They're 99% for show so I'd definitely err on the side of having them dipped. Accidentally highbeaming someone with the lazy, yellow old highbeams is no biggeee - highbeaming someone with these Mother $&#$% could actually cause an accident
edwagon
Postby STR » Tue Aug 26, 2014 7:47 pm
^This.
There is a $150 fine for using them when they're not required, think it has to be under 100m visibility.
Personally it's more the Euro cars with fog lights on that annoy me because of the extremely bright single rear fog light they have, which I'm convinced most drivers of said euros don't even know exists.
But I digress. If you're going for a rally style look, spotlights can look awesome, I guess it's just up to you if you want to fit something you can't use in most situations.
82 KP60 4AGTE race car
S.T.R - Shopping Trolley Racing!!!
STR
Postby d1 mule » Wed Aug 27, 2014 2:37 am
not that it matters, but Mud...Terrible....Disgusting etc etc, unless fully stickered up etc etc
d1 mule
Postby disturbedphil » Wed Aug 27, 2014 7:12 am
they are not a living organism therefore it is impossible for them to have a sexual preference......
on a more serious note they don't look too bad, you will have no trouble seeing at night thats for sure
disturbedphil
Postby jondee86 » Wed Aug 27, 2014 11:19 am
~SlideWays~ wrote:Also not sure how a car becomes gay, they have no penises?
On a gay car the penis is on the inside...
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby snwtoy » Fri Sep 05, 2014 12:46 pm
There are legalities around distance from corner to innermost lights. Found it once a long time ago, but can't remember where. Might be something to check before you secure them permanently.
snwtoy
