G4 AFR display
G4 AFR display
Postby 1I1 » Thu Aug 28, 2014 12:58 pm
Anyone struck with a G4/Innovate LC2 combo that they can only get an average AFR displayed in pclink?
The Innovate Gauge displays the actual AFR, but just can't work out why it won't display that on pclink.
I'm 99% sure I have wired it correctly - it's pretty basic really, but that doesn't mean I couldn't have co*ked something up haha
TRD Clicky >>Here
1I1
Re: G4 AFR display
Postby Grrrrrrr! » Thu Aug 28, 2014 1:13 pm
What do you mean average AFR? Averaged over a time period?
Are you using one LC2 channel for the gauge and the other for the ecu, or running both off the same output?
If using separate outputs, you haven't left the second LC2 output in narrowband emulation mode (assuming its the same as an LC1) have you?
Are both the ECU and the gauge using the same ground reference?
Grrrrrrr!
Re: G4 AFR display
Postby whynot » Thu Aug 28, 2014 1:29 pm
I had a go at this with 1I1 the other week. It's too do with the g4 plus software on the laptop. It would be nice to have a gauge to display the afr on the tuning screen but the closest so far is either lamda or average afr. So if someone knows where the selection is and what it is named on the g4 plus software that would be very helpful. Also it's not the same as the older g4 software otherwise we would be sorted already.
whynot
Re: G4 AFR display
Postby 1I1 » Thu Aug 28, 2014 1:34 pm
Grrrrrrr! wrote:If using separate outputs, you haven't left the second LC2 output in narrowband emulation mode (assuming its the same as an LC1) have you?
Ah that might be it - I used separate outputs as per wiring sheet. Is that second output pre setup as narrowband off the bat? If so, then that's going to need to be changed. Or I could just use the one output.
TRD Clicky >>Here
1I1
Re: G4 AFR display
Postby QikStarlie » Thu Aug 28, 2014 10:07 pm
unsure how you have it setup now. so from the start.
in pc link, setup you analog input. lambda1, set the cal to lc1. make sure you have the correct output wired in/ its programed right in the innovate gear
on the tuning view it should come up on the default gauge. if not you can add gauge, right click new veiw, dial gauge, add lamba1 under analog inputs, ok
to make the gauge read afr. go options menu and you can change from lambda to afr under "units" only seems to work for the dial gauge veiw though? i usually run a big digital gauge, as is way easyer to read. but thats on g4 software not g4 +
QikStarlie
