Drove out of garage, washed and vacuumed. Got some petrol and pumped up the tyres. She has a date with the panel and paint man, mechanic and auto trimmer today.
Current JZZ31 soarer 2jzge-T (project), Crown Athlete 3.5 (Daily) RVR Turbo (idle) Carmy Wagon 2.5 (lent to mum). Previous. A32 maxima (dead) 190e Merc (dead) Terrano (dereg for 10 years, still being driven in west Auckland)
Friday night was a mad dash to get the exhaust back on to get a WOF. Out in the shed till 11 working, got up Saturday morning to start it and find there was an exhaust leak easy fix at least woo hoo Decided to make the Corolla not look like a dirty filthy sl...... tonight. What a time consuming mission! God know what I drove through but its everywhere and didn't wash off! Bug and tar remover to the rescue! Spent four hours tonight on it and still not finished
Test fitted fibreglass RC bonnet. And fitted facelift tinted numberplate surround and a few other peices I pick up at PickAPart when we were in Auckland
Finally got around to buying new panels for my car today, shes been sitting gathering cobwebs since an accident at Pukekohe last year. https://www.youtube.com/watch?v=KJGj67bdsDQ
Tried to figure out why the MR2 isn't charging the battery. Tested voltage while car running, just over 12v on a fresh battery. Volt meter in the dashboard is sitting low compared to normal. Diode test appears normal. Fuses are all still good as is the wiring. The only bit I haven't checked is if the charge light bulb is blown. I'm not getting the usual red lights of death.
The only thing I can't test is the voltage regulator. Where is a good place in Wellington to take it for testing?
Yes, hence the not charging bit. The voltage is the same with engine off and on. The alternator is a reconditioned one I got from Repco about 6 years ago. The reconditioned one I had before that only lasted 1 month before a diode went. Then before that the factory one ate the slip rings from being ~18 years old.
