Postby Leon » Thu Sep 03, 2015 6:47 pm
I think I've had my 92 GT sedan 9 years (out of the last 12).
Still going strong, and I've had to start my third motorsport logbook on it now.
So she's done a few events now.
Postby matt dunn » Fri Sep 04, 2015 12:26 am
Had an oil leak from the front main seal,
so just finished putting it back together with a new seal cambelt and tensioner,
start it up and more oil now dripping out somewhere else,
looks like its coming out through the dist shaft now,
so time to rebuild the distributor.
Postby Lurkin » Sat Sep 05, 2015 7:47 pm
Bought another supercharged AW11, because I have a problem and cannot stop buying cars
Every time I (infrequently) come on here you've bought something new to you!
Excellent choice!
there is no cure.......
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby Dell'Orto » Sat Sep 05, 2015 10:26 pm
It's a terrible affliction! There should be a support group :lol:
Collected said AW today. Has been sitting for 6 years!
Postby rollaholic » Sun Sep 06, 2015 9:35 am
that actually looks bloody straight. thats not like you :P
Postby GDII » Sun Sep 06, 2015 10:34 am
Is that a 15" 16" wheel stagger? That looks really tidy. Some different wheels on it and it will look even better.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Dell'Orto » Sun Sep 06, 2015 12:28 pm
rollaholic wrote:that actually looks bloody straight. thats not like you :P
What do you mean, most of the cars I buy are tidy bodywise. None of them run though :lol:
GDII wrote:Is that a 15" 16" wheel stagger? That looks really tidy. Some different wheels on it and it will look even better.
14/16 actually, random as hell. Would love to find a set of Tom's C3-Rs like I had on my Levin, but wheels are last on the list. Get it running and dealing to the rust are first on the list
Postby Lurkin » Sun Sep 06, 2015 3:05 pm
Very, very, very jelly. Always wanted a supercharged one. The only ones I ended up looking at back in the day were too raped/rusted out to be acceptable.
Past casualties
Lurkin
Postby Bling » Sun Sep 06, 2015 4:03 pm
Shit that looks tidy!
Postby siren676 » Sun Sep 06, 2015 10:07 pm
Did the Gumboot rally this weekend, 2 days of twisty roads, 700km's(40km+ on gravel) and only used 60L of gas :lol:
Had a few small issues with guard rub and a missfire under full load but otherwise had no hiccups.
Was all shiny beforehand.
Got a little dirty
siren676
Postby Bling » Sun Sep 06, 2015 10:22 pm
Sweet two door :lol:
Postby phoenix » Sun Sep 06, 2015 11:49 pm
siren676 wrote:Was all shiny beforehand.
Got a little dirty
Your door handles are different colours?
11 second Honda
phoenix
Postby Al » Mon Sep 07, 2015 9:58 am
Not sure how you can go from owning an SW down to an AW :lol:
Al
Postby Dell'Orto » Mon Sep 07, 2015 12:15 pm
Owned two of each now, unlikely to find a tidy SW20 GT for what I got this for!
If I ever get another SW it'd be a gen 4
Postby siren676 » Mon Sep 07, 2015 1:18 pm
Got a little dirty
:lol: yeah I havent got around to painting them after replacing all the panels on the left side
siren676
Postby matt dunn » Mon Sep 07, 2015 11:48 pm
Damn 16V oil leaks !!
Did the crank seal,
then it leaked out the dist,
put new seals and bearing in the dist and fixed that,
now it is still dripping oil on the floor.
Have pulled it apart again and it now looks like it's the cam seals.
I thought if they were leaking that you would see it with the top cambelt cover removed,
so I never replaced them when I did the crank seal and cambelt.
But it looks like when they leak the oil run down behind the backing plate behind the cam wheels,
and runs out and down the side of the block under the distributor.
Will have to get some seals and redo it all again.
Postby Kiwi-Corolla » Sun Sep 27, 2015 8:55 pm
Ditched my shitty Made in China Erisin Windows CE based stereo for a not quite as shitty Made in China Eonon Android one and painted my calipers red for ultimate rice spec (and the free +5hp the prepubescent salesperson at Repco promised me) 8)
Kiwi-Corolla
Postby Dell'Orto » Sun Sep 27, 2015 10:04 pm
I sprayed a $&#$% of CRC around the nuts and bolts I'll invariably have to remove to take the cylinder head off the AW. Hopefully in a couple of weeks I'll be able to attack it!
Postby MAC_HATER » Mon Sep 28, 2015 9:14 am
Was done over a few days, but I decided to look at why the Corona was running cold all of the time, and things snowballed slightly
I figured I should remove the radiator and get it cleaned and tested as I could see muck in there, to my horror the radiator hoses fell apart in my hands while removing them, they would have all exploded instantly if the cooling system actually got hot and pressurized D:
So I bit the bullet and removed ALL of the rubber coolant hoses while I was there to get them replaced, they are all shot also, and hiding a pretty rusty cooling system, the thermostat housing and rear head coolant lines were crumbling and looking pretty bad, I hope they can be cleaned up and still have enough meat left to get a nice hose and clamp onto them
Broke a thermostat housing bolt trying to get to the thermostat, was able to get that out with the help of a friend, and the thermostat was clogged OPEN haha, so thats going to get replaced, we also removed the water pump, it was rumbly as hell and not long for this earth either
I gave the front end a degrease after all of this, and turns out there was indeed a pretty face under 30 years of oil and grime:
Going to pick my friends brains this week and see just how involved it is to get the front timing cover off, as I would like to replace that gasket along with the front crank seal, I figure now is a great time to do this, as I don't intend on stripping it down that far ever again haha
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby GDII » Mon Sep 28, 2015 9:37 am
Kiwi-Corolla wrote:Ditched my shitty Made in China Erisin Windows CE based stereo for a not quite as shitty Made in China Eonon Android one and painted my calipers red for ultimate rice spec (and the free +5hp the prepubescent salesperson at Repco promised me) 8)
Isn't it an extra 25kW?
What paint did you use for the calipers? I've just stated painting mine with Duplicolor brush on caliper paint but these are off the car. Makes it far easier I think, never painted calipers before.
1990 SW20 MR2
GDII
