ST215 3SGE Rocker Cover Correct Torque
Postby lord3210 » Thu Dec 03, 2015 1:43 pm
Hey there Everyone
I about to replace the Rocker Cover Seals of my Caldina but I'm wanting to know if any knows,
what the correct torque is when I need to tighten the rocker cover bolts back on again.
The Engine is a 1998 ST215 3SGE non-turbo.
Any Help is greatly appreciatted.
David
lord3210
Re: ST215 3SGE Rocker Cover Correct Torque
Postby MAC_HATER » Thu Dec 03, 2015 10:46 pm
It may not be helpful to you as its not a specific torque rating, but when I did my cam cover gasket on my ST183, I didn't torque them, but just wound them hand tight, then they took another turn on the spanner before they started to feel stiff and tighter, but not crazy clamped down, then after a heat cycle and letting it cool once again I was able to get another half turn out of them, and then on the next heat cycle I was able to get a quarter turn
checked them again a month later and they were pretty sweet, no more needed, and even before the second tightening, it was not weeping oil on the first run after replacing the seals, so you probably don't need to go too crazy with them
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby lord3210 » Fri Dec 04, 2015 5:27 am
Thanks for that mate, If I can't find the correct numbers, I'll definitely give your solution a try.
lord3210
Postby GDII » Fri Dec 04, 2015 3:02 pm
6Nm/61kgf.cm/53in.lbf is for the GEN 3 3SGE in the ST20* Celica which is similar to the ST215? Is it a BEAMS?
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby lord3210 » Fri Dec 04, 2015 11:00 pm
GDII wrote:6Nm/61kgf.cm/53in.lbf is for the GEN 3 3SGE in the ST20* Celica which is similar to the ST215? Is it a BEAMS?
Yes it is a beams, cheers Mate.
lord3210
Postby sergei » Sat Dec 05, 2015 12:32 pm
6Nm is very close to finger tight ;).
Users browsing this forum: Bing [Bot] and 26 guests
