Postby Dell'Orto » Mon Feb 08, 2016 9:21 pm
So it appears SW20 spedo drives aren't compatible with AW11's, sheared the drive pin, FML. Also keep getting code 52, that's gonna be fun to fix...
Postby Kiwi-Corolla » Mon Feb 08, 2016 9:42 pm
Dell'Orto wrote:Also keep getting code 52, that's gonna be fun to fix...
Of all the codes!! Have fun ;)
Kiwi-Corolla
Postby Dell'Orto » Mon Feb 08, 2016 10:08 pm
I suspect it's to do with the very rugged crimp joiner that's been put in there. Knew I should have fixed it before I put the motor back in :?
Postby MAC_HATER » Tue Feb 09, 2016 10:39 am
Probably the biggest work I have done in a long while with it, its been pretty solid until it failed its warrant for a dead shock absorber a few weeks back
Managed to get them all out yesterday
Turns out all 4 of them are either stuffed or very close to being stuffed, anything rubber is falling apart and the top hats have play and wear, oh well, new ones are on the way
Another benefit of the new ones is they have adjustable damping which the old ones don't have, and being shiny and new, they don't have rounded off height adjusters, the current ones are all stuffed cause it looks like some asshole had at them with a cold chisel, which is stupid as the previous owner had the correct tools when he had it, and he then passed them on to me when he sold it
I also went on a de-ricing mission, removed the air filter and BOV, and will go back to the stock recirc valve when I buy the correct vac lines and pipes, and I have a standard JZA70 airbox on the way hopefully arriving this week that I can just bolt back in
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby Kiwi-Corolla » Fri Feb 12, 2016 9:32 pm
Chucked a catch can in.
Kiwi-Corolla
Postby Bling » Sun Feb 14, 2016 9:22 pm
Oil change on the RAV today, pretty handy not needing to get a jack out for that. 8) TGP filter and Castrol Edge, that should last it till I have a garage again.
Postby andrewgreen1000 » Mon Feb 15, 2016 2:21 pm
Decided to clean up the FGK Muffler I bought for the Sprinter. Used a bit of stainless steel wool, a bit of dremel wire brush action (before the brush broke), and some autosol metal polish. Not perfect by any means but better than it was.
Went from:
To:
Its only half an exhaust, so will need to get it zapped on by somewhere the main part of the blacktop exhaust isn't too bad right? Preferably keeping flanges etc so I can put it back to stock later if need be. Anyone in akl feel like doing a cashie haha.
Current: '99 Ae111 Sprinter GT, '12 Aqua
Gone, but not forgotten: '81 KP Starlet, '92 Ae101 Truneo, '97 BZ-Touring Carib, '96 LWB Bighorn, '96 Bogan mobile Levin.
andrewgreen1000
Postby Bling » Tue Feb 16, 2016 4:09 pm
Did you use coke / lemon juice with the wool?
Postby andrewgreen1000 » Tue Feb 16, 2016 6:20 pm
I totally forgot about the coke trick! I just used some hot soapy water. Might go over it again with coke. I heard apple cider vinegar is also a go.
andrewgreen1000
Postby Bling » Tue Feb 16, 2016 6:36 pm
Yeah anything acidic should work, should bring it up even better.
Postby Boosted_162 » Sun Feb 21, 2016 5:46 pm
Chucked the motor back into the starlet.
Postby Dell'Orto » Sun Feb 21, 2016 5:51 pm
New speedo drive pin, and new knock sensor + new tyres meant I could finally take the AW for a drive! Reasonably faultless 20k drive, though 5EFE knock sensor pulls timing in odd places :lol:
Postby Boosted_162 » Tue Mar 15, 2016 7:43 pm
Got a pair of RE003's fitted to the front of the EP. Found my rear wheel bearings had a bit of play so tightened up. Hadn't checked since installing them so was expected.
Also found the right handbrake cable is gone, while the left is working alright. So will only replace the one which will save money! :)
Postby GDII » Tue Mar 15, 2016 8:46 pm
Boosted_162 wrote:Got a pair of RE003's fitted to the front of the EP. Found my rear wheel bearings had a bit of play so tightened up. Hadn't checked since installing them so was expected.
Last time someone replaced one cable on my MR2 (before I bought it) one cable was longer than the other so only one brake worked anyway.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Boosted_162 » Tue Mar 15, 2016 9:47 pm
Mine got super stretched because the rear pistons and sliders all seized, and someone just kept tightening and yanking on the lever.
At $175 each I only want to replace 1! :lol: Hopefully it works and I don't have to replace the other...
Postby GDII » Wed Mar 16, 2016 9:43 am
I got both mine rebuilt for $120 but that was over 6 years years ago. However the handbrake lever never felt great, then one day I pulled a bit too hard and the short cable on the lever in the car exploded. The cable was slowly on it's way out. Secondhand cable in good condition changed the amount of clicks significantly even though I had adjusted the old cable to try and get it working properly.
1990 SW20 MR2
GDII
Postby Boosted_162 » Sat Mar 19, 2016 4:01 pm
New front brakes on the V.
Also changed oil in the Carib :)
Postby Boosted_162 » Fri Apr 01, 2016 8:41 pm
Yesterday I replaced the door hinge. Door is no longer sagging but still play in bottom hinge. Ordered new hinges for both sides from Mark :lol:
Today I replaced both handbrake cables. After looking at it last week I decided I only wanted to do it once so did both. Only broke 1 bolt in the exhaust. Haven't really driven it but difference is immense. Actually have a handbrake now :lol:
Also picked up the piping for my oil relocation kit.
Gotta say a massive thanks to Mark for all his help with parts 8) I feel like I email for parts at least once a week (usually thursday as I get paid wednesday :lol:)
Postby Kiwi-Corolla » Sat Apr 09, 2016 6:01 pm
Quick Saturday mod - I pulled off my old foam EZ Lip and installed this glossy carbon lip in it's place. Was difficult to photograph due to the glossiness but you get the idea :)
Kiwi-Corolla
Postby dskd » Sat Apr 09, 2016 11:49 pm
well today i had a good crack at killing my fxgt
https://www.facebook.com/RubyRacingNZ/v ... 224325331/
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
