by xsspeed » Sat Oct 15, 2016 7:30 pm
Hey guys, have had the engine out of the wife's caldina doing a bunch of seals and other bits and pieces as it decided to turn british on me.
Have got the engine back in and its cranking but wont fire.
I seem to get pressure at the fuel filter (when i crack the banjo bolt it squirts out but not a huge amount). Have disconnected the return from the fuel rail and extended the line to a bottle, but with key at either ign or start not flowing anythin gout of the return.
I have checked and swapped in a different 15A fuse in the engine bay, removed and reinserted the engine bay efi relay, I think there is another in the passenger footwell?
Across the pump plug I get 5.8V across 2 pins when key is at ign, drops to 3.7V when cranking. There's 4 wires going into the plug but can only detect a voltage across two of them.
I havent checked spark yet as trying to rule out fuel
Should I be getting 12V at pump?
If im getting some pressure in the supply line between filter and rail do I have a block?
Edit: damn realised i was measuring volts across pins and not to body/ground, will recheck
xsspeed on Mon Jan 16, 2017 9:27 am, edited 5 times in total.
