i have purchased an ae111 to use the engine in my suzuki sj410.
the engine had a suspected blown head gasket, and upon opening it up we discovered it dosnt look like it was very well looked after. the head is filthy so i will remove the valves and i want to get it cleaned. where is the best place to take it?
i will be replacing all the seals and gaskets, trd head gasket, head bolts and most likely bearings. i am trying to avoid spending big bucks on it since it wont be daily driven on road. there is a mark in 1 of the cylinders that i am concerned about. what do you think?
ill be getting new spark plugs, leads, dizzy, knock sensor (they are all damaged).
