Core plugs - material and installation
Post Reply
Vertigo
Post by Vertigo »
The Silvertop in my AW11 developed a hole through one of the head core plugs (underneath cylinder #3 throttle body). Ive popped it out, but had such a bitch of a time trying to get the new one in, that i bent it out of shape. Have a new one now, but damn, space is super tight, angles are difficult.... any suggestions? Thinking either take the throttles off, or the cylinder head itself.
Also, what material should I be using? Steel, or brass? The previous one was steel, very magnetic.
TVIS just kicked in, yo!
Re: Core plugs - material and installation
Post by Dell'Orto »
Remove a driveshaft and see if you can access it easier from underneath? Brass is better, doesn't corrode.
MAGN1T
!USER HAS BEEN BANNED!
Post by MAGN1T »
Use antifreze, then it won't rust out.
Computers make you go mad.
Vertigo
Post by Vertigo »
Quite, but this engine came from any number of cars previously, and I came with the car when I bought it last year.
Anyway, its replaced now. Gave up and had a workshop do it!
Post Reply
