Caldina GTT Driveshaft bushing gone?
Postby Technohedge » Sun Nov 10, 2019 7:07 pm
This is a pic underneath the caldina, looking at one of the driveshaft support mounts. Has the mount gone? (looks like its not centered) or are they always like this?
Have a knocking noise when i come off the throttle under the car and wondering if this is the culprit
Technohedge
Re: Caldina GTT Driveshaft bushing gone?
Postby GDII » Mon Nov 11, 2019 8:23 am
Looks rather stuffed to me. Should look like this.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Technohedge » Mon Nov 11, 2019 11:28 am
Cool thanks man,
is that the correct part number on there? Are they easy enough to swap out?
Technohedge
Postby GDII » Tue Nov 12, 2019 3:26 pm
That is ONE of them. There are 2 bearings but I don't know which one yours is.
As for changing them out, I have no idea but I'm sure the internet has information on how to do this. The Celica or any Toyota/Lexus of the 90s should be the same.
1990 SW20 MR2
GDII
Postby Technohedge » Sat Nov 16, 2019 8:43 pm
Ok ddoes nyone know how i split this beast apart? There is a bolt in the left end of it i can probably remove to get the left hand bearing off. But how does the right hand side split?
Any reason there are two hanger bearings on the caldina whereas loads of others seem to have only one?
Technohedge
Postby Bling » Sun Nov 17, 2019 5:41 pm
Look your car up on here: https://www.amayama.com/en/catalogs/toyota?_s=h
It should show exploded view of parts
Postby GDII » Mon Nov 18, 2019 10:48 am
Seems like the CV joint needs to be opened up to access the end bolt for it. Same as the other end you can get access to easier.
1990 SW20 MR2
GDII
Users browsing this forum: Bing [Bot] and 17 guests
