Toyota Corolla RUNX information please?
Chickenman
I Am The Walrus!
Contact:
Post by Chickenman »
TRD Man wrote:
Chickenman wrote: That is where the only valid comparison can be made as a bzr should go around a circuit more quickly.
Care to qualify that?
I dunno, that's why I was asking.
Does a higher rear weight bias make a difference? Does lighter weight and therefore later braking make a difference? The power to weight ratios are pretty close (assuming the runx has all the power that is claimed.. claims come from the same place for the b/t and the 2zz)
You would assume the later and therefore more developed car would outperform the older model but I think they would be pretty even.
I don't really know, just good to discuss these sort of things I guess. Someone always comes out with something definitive eventually.
The celica on the other hand... Mmmmmmm :D
The pictured car managed a 15.3 in stock form (with the flappy bit that controls the intake below 3000rpm removed) and that's pretty good for a fwd.
I do think the 5 speed box would be better in all of these cars though, what you guys think?
Baby Jesus
regamaster
Post by regamaster »
yes the 140KW model with 6 speed is what hes looking at, I still dont have many good answers on these. Anyone got any sites that have some very good specs outlined etc?
Chickenman
I Am The Walrus!
Contact:
A russian site but has basic specs for most import cars..
http://english.auto.vl.ru/catalog/toyot ... 02_9/2901/
Baby Jesus
TRD Man
Contact:
Post by TRD Man »
Mr Revhead wrote: certainly eats a 20v for power
Not to mention torque.
And of course there's also stuff that happens between the motor and the wheels i.e. gear ratios.
With a 4.550 final drive ratio the RUNX gets away quite smartly.
barryogen
2ZZ Guru in training
Contact:
Post by barryogen »
Jazza wrote:Personally i dont like the shape and from what ive heard (I dont know this for a fact, do NOT quote me) They are nanny wagons.
heh, some are, some arent, it depends on the engine.
barryogen
Contact:
Post by barryogen »
suped wrote:Are they performance cars? No.
arguable, for a FWD NA car, they're pretty damn good, it's a pity that the 4wd one doesn't come with the good engine.
barryogen
Contact:
Post by barryogen »
snwtoy wrote:I'm not sure which model it is, but one of them has a power to weight nearly identical to the caldina GT-T. Coupled with a 6-speed box and you are looking at a very quick little car.
that would be my one... :)
RunX Z is the 6spd vvtl-i
http://english.auto.vl.ru/catalog/toyota/corolla_runx/
barryogen
Contact:
Post by barryogen »
Chickenman wrote:
nzae86 wrote:Have one as a road car , yep go pretty well with 140kw, bit of a wolf in sheeps clothing. And yeah seam to have very small pictures of 20valves painted on the rear vision mirrors.
Does anyone know what they do on the quarter? 140 kw in a 1220kg car compared to 120 in a 1060kg car has them pretty even..
although I've seen the runx weight listed as 1160kg which would have it ahead on power to weight by a wee bit.
14.73 is the quickest I've seen mine do it... I wasn't driving, some other fulla who can actually do drags(well, compared to me with my 16.xx) was :)
mine comes in at exactly 1140KG with a full tank of gas, and no driver... unfortunately I add another ~130kg to that :(
Chickenman
I Am The Walrus!
Contact:
I'm impressed, that's quite quick and does leave the ae111 behind. Yours is standard?
Now what's this "Type-R" thing that everyone talks about... :lol:
Baby Jesus
barryogen
Contact:
Post by barryogen »
Chickenman wrote:I'm impressed, that's quite quick and does leave the ae111 behind. Yours is standard?
well, no.
I got it as an import, and it has had a few things done to it.
Air box is gone, had a pod sitting in the open engine bay at the time, now has CAI.
Exhaust has been changed, but to what extent I am unsure, it has since had one of the silencers and the CAT taken out, and it has freed up the high end.
From factory they have 4-1(of sorts, more like a hybrid 4-1 and 4-2-1, hard to explain) tuned exhaust.
The 140kw is at the crank, but they seem to give ~120kw at the wheels from dynos I've seen, and getting them to 140kw is "easy".
I have some info on my site, and I am continuously updating it(although I haven't in a while)
regamaster
Is yours a 4WD or 2WD?
that cold airbox of yours, is that a local company or a overseas company?
14's is a very quick time for a shopping cart.
has yours been dyno'd?
does anyone know what parts TRD sells for these bolt on or if they do any at all?
barryogen
Contact:
Post by barryogen »
hatchedin96 wrote:Is yours a 4WD or 2WD?
2WD, FWD, the 4wd one has sucky engine.
Cold air box was done locally, Daniel Robertson, Ridez custom fabrication, ridez@email.com 03 4740020 awesome guy, and excellant work.
Not dyno'd yet, but will be prior to a few upgrades.
TRD you say...
http://trdparts.jp/english/list_zze.html
Everything(almost) availible for the Celica is availible for the RunX and Allex(and the Will maybe?)
nzae86
Post by nzae86 »
Well heres someone that got his going even faster to the supermarket!
http://www.damseauxmotorsport.co.za/rally_car.htm
Your addiction to motorsport can only be cured by poverty!
barryogen
Contact:
Post by barryogen »
nzae86 wrote:Well heres someone that got his going even faster to the supermarket!
heh, thats cheating doing an engine swap.
Theres a 600HP(I think) RunX that does drags, 3SGTE 4WD, but again thats hardly the same car.
TRD Man
Contact:
Post by TRD Man »
hatchedin96 wrote:does anyone know what parts TRD sells for these bolt on or if they do any at all?
We do. http://www.trdsales.com/shop/product.asp?catcode=335
ROBODISCO_20v
Contact:
Post by ROBODISCO_20v »
14.7 is about the same a decent AE111 with a good driver behind the wheel. I've run a 14.9 in mine on a unprepd track so I expect to shave a few 100ths of a second off that with some VHT layed down.
The best set up I've seen for the 2ZZGE is to put it into a MR-S. Then they haul arse as they only weigh about 1010kg !
barryogen
Contact:
Post by barryogen »
ROBODISCO_20v wrote:14.7 is about the same a decent AE111 with a good driver behind the wheel. I've run a 14.9 in mine on a unprepd track so I expect to shave a few 100ths of a second off that with some VHT layed down.
Turbo kit...
http://www.hassturbo.com/catalog/toyota.html
vids(dyno and drag)
http://www.hassturbo.com/video/video.html
Chickenman
I Am The Walrus!
Contact:
ROBODISCO_20v wrote:The best set up I've seen for the 2ZZGE is to put it into a MR-S. Then they haul arse as they only weigh about 1010kg !
*cough* Toyota Racing Series *cough*
Baby Jesus
ROBODISCO_20v
Contact:
Yes well TRS is the best but i was refering to street use
regamaster
thanks for the introduction information all. My friend has just laid a deposit on an 01 RunX Z 6speed vvti model, and it is silver. He also just put a deposit on a new pug 307 in black so, two hot hatches in his garage.
Hes definitely going to modify the RunX though, hes very eager on TRD parts though.
barryogen - thanks for the information and I'll give him the contact for that fabricator.
Post Reply
