s/c bov??
It would be bugger all extra accelerating time anyway, BOV isn't going to help things. The excess pressure the BOV would be releasing would be after the throttle and the way a BOV works is by using intake vacuum (after the throttle) to open the BOV and release any extra pressure that has formed before the throttle. If you try to set up a BOV on the supercharged engine with lots of piping to fix the problem you speak of then there is always going to be the same pressure on either side of the BOV and it'll never actually open.
- Mr. Mainstream
- Toyspeed Member
- Contact:
i like my skank Whistle
75 MK2 Ford Escort L 2.1L
Various Others
Various Others
CozmoNz wrote:Running rich only occur's in Air Flow meter'ed car's
where the PISSHHHH noise releases the boost when the engine's ecu belives it will receive that air. and injects the approperate fueling.
with a map sensor'ed car, the ecu will only inject what the engine *thinks* (due to mapping etc) it will need fuel wise... i think thats right, so @ x of vac, it injects x of fuel.
losing that air / boost, results in higher vac / lower boost whatever, so less fuel is required, since less pressure exists.
thus, wankie bov's on afm'ed cars = silly and cause engine to hate you
wankie bov's on map sens0rz0red cars = the shiz wizza gizza
Wtf? Thats err ... very incorrect
Dude, you really need to stop posting such inaccurate nonsense
Cosmo had a confused way of saying it-
AFM - measures air volume pre turbo, if you run a vented rather than plumbback BOV you are venting air that the computer has already fueled for therefore the car runs rich.
MAP - measure the air volume from the inlet manifold AFTER the throttle butterfly, therefore any air vented by the BOV has not been measured by the computer so does not affect the fueling.
Callum
Callum
- Santa'sBoostinSleigh
- ** Moderator **
- Contact:
so would a vented BOV be a good thing or a bad thing on a caldina?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
- Mr. Mainstream
- Toyspeed Member
- Contact:
WHAT HAPPENED TO DR.X and Cosmo?
Various Others
Various Others
event2 wrote:dont u get continued acceleration on a supercharged engin if u hav a frount mount inter cooler and lots of pipeing? would a blow off valve stop that in this situation?
No it would make it worse, The throttle closes to stop air getting to the engine to slow it down,
an open BOV would let the air in again and cause the throttle hang longer.
Dragger_Dan wrote:It's amazing to listen to the amount of excessive noise people make with BOV's and screamer pipes. The thing I don't get, is why do you sometimes hear a BOV on a full throttle gear change... isn't that counter productive? Shouldn't a well tuned setup mantain boost pressure at WOT changes to keep as much power as possible?
At WOT the turbo may be flowing 50 (or whatever) litres or air a minute, and when you close the throttle so it doesnt go into the engine, where does it go.
Two options,
The BOV open and lets it out so the turbo can keep spinning,
OR
The turbo blades must slow down or stop pumping air into the system as it has no where to go.
- tsoob
- Toyspeed Member
- Contact:
Dr-X wrote:No, they're wanky because on 99% of applications they're pure rice. So morons like you can cruise through town in 1st and go 'listen to maah phat blow off valve, braaaah, it's turbo braaaah'.
idiot!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
- touge rolla
- Toyspeed Member
- touge rolla
- Toyspeed Member
yeh i only get looks from chics when the skank whistle goes off otherwise its just dudes staring at intercooler
4x4 toyota blizzard offroader
