lsd celica boxes
LowRydr
lsd celica boxes
Post by LowRydr »
are all 3sge fwd gear boxes interchangable, i was going to use a v6 camry box for its stregnth, but it doesnt hav lsd, so wondering if theres anyother box i can uses in a st162 that has lsd?
///TRD Toyota Racing Development
take a really hardcore project idear, making it a reality? .....im 70% there
celica_tommo
Post by celica_tommo »
I beieve they are all interchangable and most fwd celicas use s series boxes.... they only lsd gearbox that I know of made for celicas is in some 94-99 celica/currens. Thats the E-56. I think the E series boxes are supposed to be stonger internally too.
The E-56 has thicker driveshafts though so you'd need them but it should match up
Contact:
Re: lsd celica boxes
Post by matt dunn »
LowRydr wrote:are all 3sge fwd gear boxes interchangable, i was going to use a v6 camry box for its stregnth, but it doesnt hav lsd, so wondering if theres anyother box i can uses in a st162 that has lsd?
All V6's are auto's though.?
Jools
Contact:
Post by Jools »
I use an ST-202 FWD LSD box in my ST-182.
Fits just fine, tho needed to adjust a mount slightly.
Dont know about shafts tho, I ditched the 182 celica ones for some supercharged levin shafts.
I think the 202 shafts may have been too long to fit in the 182, cant remember. Regardless. if you use different shafts, you have to make sure they fit in the hubs, or replace the hubs. Had the levin shafts machined down to fit in 182 hubs
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
LowRydr
Post by LowRydr »
hey jools how much did it cost for an ST-202 LSD box and supercharged shafts. and how much to machine them down. did u use 182 everything else?
Jools
Contact:
Post by Jools »
I got the box cheap, but they usually go for about $1000
Dunno how much the shafts were, cant see them being expensive.
Same goes for getting them machined
Everything else is 182, cept maybe the clutch slave, which i think came with the box.
90 Celica GTR Turbo
www.Jools.tk
Contact:
Post by Mr Revhead »
id think an st202 lsd box would be kinda rare... i may be able to find one if ya want though. as for gze shafts can do a set for $405
dodgy
Contact:
Post by dodgy »
what about using the mr2 box, i got one from local wreckers for $300, its LSD and also got the turbo shafts as well.
Contact:
$300?? i dont think he knew what it was! you may need to do a few mods to sort out the linkages on an mr2 box
Al
Contact:
Post by Al »
Has he got another one!!!!! Gimme! The cheapest i could find was $850 with a 3 month warranty....and then it only has a viscous lsd
Jools
Contact:
Post by Jools »
I think most if not all factory LSD toyota boxes are viscous?
All my stuff was secondhand aswell, fark paying new prices.
I think Toyotas Galore (think thats what they called) had a 202 LSD box recently, but they wanted $1200
90 Celica GTR Turbo
www.Jools.tk
Contact:
Post by Malcolm »
you can use a SW20 MR2 LSD box but you need the shifter arm from a gt4 gearbox, or possibly an st202 box, you will also need to plug up the old hole from the stock shifter arm.
If you simply want to get an LSD without too much stuffing around, and don't need the extra strength of an E series box, it might be cheaper to get a sanding block type LSD and install it into your existing box. They are relatively cheap (search the MR2 forums for info), the most expensive part being the installation, as the gearbox has to be partially dismantled.
celica_tommo
I've got a spare gearbox that I wont be using that I suspect is an lsd. It will bolt up to a 3s-ge... was sold to me (I hadnt seen it till I had paid and been sent it) as st-182 celica box... but looks exactly like an E-56 lsd from a st-206 curren that I also have.
so to check for sure all I need to do is stick a driveshaft in one side... spin it.... hold the input shaft still and see what way the other side turns right?...if it turns the same direction lsd, if opposite non-lsd?
I'll sell it if someone wants it after i check.... but the reason I didnt use it is cause i is missing a slave cylinder, speed sensor and shifter arm.
Contact:
a simpler way to check for E series lsd is look throught the hole where the shafts go, if its lsd there will be a bar running across the hole. if non lsd there will be an unobstructed view through the hole.
celica_tommo
cool.... well I have an lsd box then... I think I will hold on to it for a few weeks till I am sure I dont need it.... but after that it's up for grabs
LowRydr
Post by LowRydr »
local wreckers quotes me for a st202 $1200 for jsut the box :S i have like bugga all money - i have things to trade/sell, like topmount intercooler off a 2003 sti wrx, and some other stuff.
ive brought a manual celica st162 for the parts but it odesnt have lsd,
Mr Revhead - if u could please price me one cheape up id be appreciated
celica_tommo - if it is lsd how much u want for it? wat else do i need to make it work? .. iu didnt think the st-182 celica's had lsd :S
celica_tommo
Its a gearbox that I assume is from an st202 celica or st206 curren
I own what I know is an E56 lsd box from a curren and the one i will be selling looks idedntical
As I said it was sold to me as a st-182 box but when I had a look at it its definately not the gearbox I was expecting to see. I bought it off a guy tat bought it from an engine importer. There are no lsd st-182 gearboxes
It is missing and needs these things: speed sensor (whole unit including the gear and eletrical connector), slave cylinder (but thats easy to pick up, your one on your old box might fit, but lots of people buy new anyway), shifter arm (probably also not so hard to get hold of, one of another gearbox might fit)
I will probably want about $300-400 for it or more if the buyer wants me to get the missing bits and pieces for it. Beacause I dont know the history of it though I can give you your money back if it turns out to be shit.
So if you want it in a few weeks that cool... but I am going to hold onto it just in case my other gearbox is no good
celica_tommo
where do you live LowRyder?
Contact:
so far have an e56 box with lsd from st202 celica for $830inc gst. comes with shafts if you need them.
also sw20 turbo box for $513 maybe lsd geting that checked.
confirmed lsd :D
Contact:
oh and one more at $520inc gst comes with shafts out of st202 carina. again double checking lsd
also confirmed lsd :D
Post Reply
