twin-charge trueno
dragg_racer666
twin-charge trueno
Post by dragg_racer666 »
hey can any one tell me about twin charging my 4agze trueno.. were can i get a turbo kit to add to my already supercharged engine. and what sort of work dose it involve. any info on twin charging my 4agze trueno would be alot of help. thanks
shaggz
why you wanna twin charge???????????
Post by shaggz »
im pretty sure it can be done but wot are you trying to achieve you could get a bigger pully kit for supercharger adn score sum more boost
or you could take that blower off and slap on a turbo i remember altho a couple of years back i had a hotfours or fastfours mag and there was an fxgt hatch that wastwin charged but i cant remember how long ago and cant find my issue either
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
Dr-X
Post by Dr-X »
This falls into the "If you need to ask, you cant do it" category.
Post by Adamal »
If you don't know enough about it, it's not one to attempt. It gets bloody complicated from what I've heard. And what I haven't heard is probably even more complicated!
Contact:
Post by matt dunn »
We have played around with twin charging and it's twice the work for 1/2 the gains of a turbo conversion.
dragg_racer666
well it'll be done. there is another twin charged levin in dunedin and i want a race it. also i want to get some 12's or so. i've got the pully kit on order. well i mite justtake it to a performance shop and get them to do it and then play more with it.ihave a garret T3 off my old GTX in my guarage so that should do the trick. and also i want to prove to my mate that i CAN make my jap peace of shit as he says beat his chevy. but just with a supercharge i dont think it'll do it.
Contact:
Post by Bazda »
good luck man, cant wait to see that bill for twin cahrging, i would think around the 10K mark from a decent garage that knows what they are doing.
Advanced Imports has done it, they said it was so complicated they spent so much time and $ on it and they couldnt get the change over fully right, always had a lag between turbo taking over from the s/c. Their reccomendation was to just turbo it!!! so thats what I did like most other people on here.
dragg_racer666
thats the thing man. i dont want to be like most people. iwant something that no one alse has. something different. i used to work in a guarage and know alot about cars. i honestly dont think it'll be that big of a job. i think the only prob will be retarding the spark enough for the turbo. i mean i have all the equiptment tomake any type of pipes i need and have basic knowledge on how turbo engines are set up.. when its done i'll let all use guys know how it goes. but if any one out there has some helpfull knowledge on this any input would be helpfull.
RedMist
Contact:
Post by RedMist »
dragg_racer666 wrote:. i honestly dont think it'll be that big of a job.
Want a Pixie Caramel with that quote?
Seriously though... you want to do some research. Find out why people with a good knoledge of boost ended up dumping twin charge solutions. You also want to try and discover why there aren't any twin charge race cars anymore, like there were in the 80's. You also want to discover how you are going to create the boost, on which device at which rpm, how your going to switch between the two, and how your going to control the switching and max boost.
You think its easy, your kidding yourself.
You think it'll develop more power than a single turbo solution, your kidding yourself.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
EVLGTZ
Contact:
Post by EVLGTZ »
heh good luck.
Just go with a nice ball bearing turbo and that'll be plenty to do what you wanna do.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
toyonut
Post by toyonut »
have a look on the net, there is a kit by hks or similar jap performance shop to twin charge the 4agze, might pay to find one or try copy some of the bits.
Stealer Of Souls
Post by Stealer Of Souls »
Well... I think I'll break the mould and actually post something constructive...
http://come.to/twincharger
This dude has done at least one twincharged engine. He's tried/trying two different setups.
SC first then turbo and now a turbo first then SC.
Good luck with this, if you get this to run well then you should post some results up since I'm wanting to twin charge my AE85.5, but won't be starting the research for that project properly for about 12 months (darn Student Loan).
'86 AE85.5 Levin
Contact:
Post by deaf_rattle »
good luck with it, but yeah it would be hard to beat a set up like jades or barrys.
Bang for buck man go turbo.
also there is more weight with keeping the s/c set up, where as im sure the turbo conversion would not add significant weight over the stock s/c set up.
barry should get into the 12s next time he drags, and im sure he hasnt spent that much on his set up.
you want to do something different?
there arent enough cars with the turbos poking out of the bonnets around :twisted:
Dr-X
Post by Dr-X »
dragg_racer666 wrote:i honestly dont think it'll be that big of a job. i think the only prob will be retarding the spark enough for the turbo.
*holds back roaring laughter*
Dude, if you want to run 12's, get a V8. If you want a quick Levin, turbo it. Twin charging will be counter productive to your goal.
Post by Adamal »
I imagine you'd have to use stronger internals too.
I think it was Matt Dunn that made a post saying that the one he toyed with produced something like 30psi @ 1000rpm
Contact:
Post by matt dunn »
Adamal wrote:I imagine you'd have to use stronger internals too.
Yes, we ran turbocharger blowing into the supercharger and the boost was uncontrollable. In the end we got it to run a consistant 20psi all the time, but it was not a huge power producing engine as at those pressures the supercharger robs to much hp off the engine.
we changed to turbo only and it is both faster round the track and faster from a standing start.
Matt
peas
Post by peas »
The magazine with the twin charged red FX rolla is the HOT4's Annual 2002. I happen to have it here. Though reading through it, it seems to focus more on the pathetic body work of the car than anything actually important in typical HOT4's fashion. In my opinion you'd be better of putting the larger SC14 on it and raising the boost with a pulley or as people had said... turbo it, cheaper and probably better gains too.
'97 Caldina GT (ST215G)
FLAWLES
Post by FLAWLES »
you will be hard pressed to find a HKS twin charge kit there pretty much non existant now..........maybe 2nd hand but not new
you could make your own but talk about piss arse around, the biggest thing to sort out would be the change over trough the bypass valve " bpv " which mounts on the s/c interheater
just go turbo like bazda or evilgtz
*********** cough like me when i get a turbo ****************
shaggz
Post by shaggz »
why dont you bolt a 4agze on to the bottom axle of a shopping trollley from the warehouse and convert a racing gocarts rear axel and brake set up on to this jump in and strap on a helmet that should catipult you into the 12's easy peasy providing the shopping trolley dont have shopping in it.......................................... good luck for the conversion probably the hard way round for the same result slapping a descent turbo on would give i commend your inginuity.............. hell im gonna put nos into my 1.6 4afe wagon wont cut twelves maybe 20's......................[/quote]
jondee86
Why did HKS build a twincharger setup ??
Post by jondee86 »
I spoke with a guy who was building a twincharger 4AGE a few years back.
The idea is to use the off-idle reponse of the supercharger for a strong
bottom end, and give the turbo a chance to spool up. Then as the revs get
up and the supercharger starts to flatten out, switch over to the turbo for a
strong top end.
The supercharger and turbo are in parallel with a servo controlled waste
gate type arrangement changing from one to the other when the boost
from the turbo is higher than that available from the supercharger. Best
of both worlds, and you can use a big turbo without having a lag problem.
The most difficult thing was to get the transition nice and smooth to avoid
having a "bump" in the boost curve.
Cheers.... jondee86
Watch this space >>> <<<
Post Reply
