OK need to take my amps out of my FXGT for the sale but dont have a clue how to get the front seats out as i got the amps put in by car audio company.
Can someone tell me how to take them out? Pics would be helpful + i would asume the seats would be the same as ae101 levins/truenos. Thanks
Front Seats in AE101 FXGT
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
- simonlenihan
- Toyspeed Member
- Contact:
Under each corner of the seat, at the end of each seat rail there will be plastic covers which hide the bolts that you are after.
They are a bit of a bugger to get off but - using a screwdriver and a bit of swearing your can get the plastic covers off by (in general) levering the side of the plastic covers outwards to release the clips that hold them in place.
Then you will need 14mm socket and ratchet to undo the bolts.
Ken
Hamilton
021 408 863
Ken
Hamilton
021 408 863
- Caveman
- Toyspeed Member
- Contact:
If they are mounted under the carpet (like a good install would be) you will also need to remove the seatbelt which is a 19mm socket then remove the small piece of trim which runs along the bottom of the door way. Pull the carpet up and done.
If you are removing the driver seat as well there is a little wire which needs to be unpluged before you remove it. It tells the car that someone is sitting in the front seat and is for the seat belt warning. Unplug it before you remove the front seat. I found this out the hard way and just pulled the seat out ripping the wire out of the seat, all that happens is the seat belt warning light never comes on again.
AW11 Track Toy
Formerly known as 1998
- slighty_sykotic
- Toyspeed Member
