Picture of 4k engine bay
Hey, just asking if some people could post pictures of there engine bay with a 4k in it?
Just need to make sure my vacum lines a correctly hooked up.
As at the moment the motor is running sweet, idling well but is abit hesitant (sp) at low revs.
I have the hose comming out of the carb and connecting to the intake manifold and no hose going to the Ignition advance unit on the side of the dizzy.
Thanks
James
Thanks
James
i have a picture of a uprighted 5k from above if thats any help? i think i got it from www.rollaclub.com
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
z|gen wrote:intake to carb ? or do you mean from the filterbox ?
you will also need a hose from the dissy to the carby..
Nope not that one, it comes out of the front of the carb and goes straight down to a connection on the intake manifold, I'm sure it surposed to go from the carb to the dizzy but it runs ruff as like that
Had flash sig, but too big for TS
OK i've fixed up the vacum hose and thats sweet,
Still having hesitation issue at low revs, and the other thing is frist thing in the morning when i pull the choke out and start the car it runs and then dies even though the choke is all the way out?
would that mean that my fuel mixture is either to rich or to lean?
It's like the choke is killing the motor, by stuffing up the mixture. hard to explain
Get in car, pull choke out turn key, no gas pedal
car starts then dies, start again car dies, turn key again car starts quickly put choke back in so motor doesn't die again and put foot on gas once again car dies.
Do the same thing again and it eventually starts, its not like the 2k where pull choke out, turn key motor starts runs mint
moogoose77
- Toyspeed Member
Try this...
Try this... Quarter choke, 2 pumps on the gas and start it up.
I don't use my choke at all. I just pump the gas once and then hold it on a lil til it starts.
It's a common problem that carby cars have when they are cold. Just idle it for a bit in the mornings before you go on to the road, it's a very sickly feeling to accelerate out on to the road and have it hesitate.
