Post your NA 4AGE Dyno Runs here
Post Reply
ROBODISCO_20v
Contact:
Post by ROBODISCO_20v »
All you out there with Naturally asperated 4AGE's 16 & 20 valve post your dyno runs here to compair. I know they're not acurate comparisons but I'll be interesting to see power & torque curves anyway.
This one was done at a NZPC/Torque Performance dyno day.
This is my AE111 Levin when i first bought it. It had a HKS pod filter, N1 style exhaust & possibly cams but we couldnt' find any markings on them when we had the engine apart to say they weren't standard. As you can see from the fuel it was running very lean at low revs
Will take it for another run once the engine is run in from it's rebuild.
suberimakuri
Contact:
Post by suberimakuri »
www.garagedori.com/tech - look at the top of the page.
Post by Adamal »
101KW at the wheels.. Thats not bad! Good job :)
B1NZ
Post by B1NZ »
dont have a scanner, but mine got 95.5KW@ the wheels on a hub dyno at 7800rpm
Stock except exhaust
Subaru GF8 Wagon
Subaru GC8 rally car project
Fortyone.co.nz
Contact:
Post by Fortyone.co.nz »
Cracked the 100 =] The best thing you could do for a few kw's is ditch the HKS filter and slap on an Apexi.
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
4AGE 8U
Contact:
Post by 4AGE 8U »
i posted mine up 2 years ago in my bzg and i made 113kw, with exhaust, cams and factory trumpet with no plenum
ROBODISCO_20v
Contact:
Fortyone.co.nz wrote:Cracked the 100 =] The best thing you could do for a few kw's is ditch the HKS filter and slap on an Apexi.
1 HP more :!: WooHoo
Better filtration though.
http://www.max-boost.co.uk/max-boost/im ... r_test.htm
http://www.mkiv.com/techarticles/filters_test/1/
vvega
Post by vvega »
lol
what a load of shit
NILPSI
Post by NILPSI »
I lost my print out in a box when i moved, but i made 101kw @ wheels on a rolling road with intake, exhaust and SAFC
Go the K&N!!!
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
GGnz
Post by GGnz »
No idea but mine will be higher :lol:
GGnz
Post by GGnz »
vvega
Post by vvega »
perhaps at the motor with no ancellerys and very cold air :D
v
Truenotch
Contact:
Post by Truenotch »
[quote="GGnz"]Isn't stock standard 121.36 kw?
Thats Flywheel kw.
Post Reply
