how wide can you go, ae92 fxgt
- deaf_rattle
- Old Skool User!
- Contact:
how wide can you go before tyre width becomes an issue.
ae92 fxgt
ae92 fxgt
See the animal in his cage that you built. Are you sure what side you're on?
You are all c**ts, ill kill you all
supported by
Click for boobies
supported by
Click for boobies
- Caveman
- Toyspeed Member
- Contact:
Im running 195 and the rear is 2mm off the strut and pretty much inline with the gaurd. I think its on 6 inch rims with 35 offset, not sure though...
205 would probably be a maximum.
- Caveman
- Toyspeed Member
- Contact:
Jazza wrote:6 foot rims?
THA SHZ dont you have flares (bash out guards
My car is lowered too, around 45mm, rubbing on the front with hardish cornering, easy to fix though.
Rear is 5mm off the strut, about 20mm away from the outter lip of the guard on 195/60/14 35 offset
Front is fine.
Could probably go 205/215 at maximum as THA SHZ said.
- soopachargen
- Toyspeed Member
- Contact:
i have 205/40/17s on a 17x7... with shagged shocks it used to rub in the back under hard cornering but now with the new ones its fine.... it sits with the top of the rear rims in the guards with people in the back and still doesnt scrub my cars an fx-g 4 door tho so i dunno if i have the same inner gaurds at the back... my plastic inner gaurds at the front have been removed and there is a polished piece on the end of my gze gearbox from full lock...
When in doubt, down and out.
205/40/17 and as low as can go and sweet on rear front had a lil rubing at full lock but put it a lil higher and cause of that no more rub
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
