Compession test
- trueno_20v
- Toyspeed Member
Compession test
Done a compression test on my silvertop 4age today and got:
160 150 160 160 psi
sound right??
i wound it over about 4 times maybe it wasnt enough?
160 150 160 160 psi
sound right??
ADMIN EDIT: signature too large
wow thats really interesting, my smallport has 250psi across all cylinders
surprises me how much more pressure i seem to have
AE85 Trueno *For sale*
Details of car here
Details of car here
Punter wrote:AE85coupe wrote:wow thats really interesting, my smallport has 250psi across all cylinders
It can vary hugely, ie throttle open or closed, cam overlaps/timing etc. etc. Infact 4afes will sometimes test higher than 4ages.
yeah that makes sense, i wonder what smallports usual compression is
Details of car here
Details of car here
- trueno_20v
- Toyspeed Member
Actual readings between different gauges cant be compared. They all read differently, whether its because of design or gauge calibration, I dont know.
Compression tests are only useful in comparing the readings between cylinders.
I actually quite like leakdown tests but they are a bit more time consuming to do.
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
AE101 4AGZE
KP60 4AGTE project
i have 180psi across the cylinders on my GZE
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
