Cambelt tensioner
Post Reply
trueno_20v
Cambelt tensioner
Post by trueno_20v »
im changing my cambelt on my silvertop, ive got everything off easy as but the bolt that holds the tensioner on wont come undone ive broken a couple of sockets and its now rounded the head on it and i dont know how im gonna get it off? any ideas?
ADMIN EDIT: signature too large
CAMB01
Post by CAMB01 »
Hit the head of the bolt with a hammer a few times then try agian.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
Post by bluemaumau »
obvious, but crc?
good luck
Ae92typeX
Post by Ae92typeX »
maybe invest in some better sockets in the future also. I gave all my sets hell, and mis-use them for all sorts of things, but have never broken one.
if the crc or hammer does not work, file down to the next size socket first. if still not work you could weld something on for leaverage, or even grind off heads, remove tensioner and tackle it then with a little more room.
20v_rollaboy
Post by 20v_rollaboy »
Ae92typeX wrote:or even grind off heads, remove tensioner and tackle it then with a little more room.
Exactly what I was thinking. Be careful the bolt dosnt break off, leaving the thread in the block, or rather the housing
AceSniper
Post by AceSniper »
if you have a bolt to replace it (prolly need to now its rounded...
grind/cut the head off it then slide the tentioner off... with out the pressure of the tentioner there you will almost be able to undo it by hand or a pair of vice grips... sounds abit butchery but it works if nothing else does
trueno_20v
yea ended up grinding the head off, undone the rest of the bolt by hand, brought a new tensioner and its all back on sweet as
RickGT
Post by RickGT »
nut f&*kers work really well, a tip for the future
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
trueno_20v
RickGT wrote:nut f&*kers work really well, a tip for the future
vicegrips??
yea wats that?
CAMB01
Post by CAMB01 »
yea wats that?
POLYGRIPS
trueno_20v
CAMB01 wrote:
yea wats that?
POLYGRIPS
lol polly grips arnt the right things to use even VICEGRIPS didnt get it off..
kingcorolla
Post by kingcorolla »
some polygrips will out-grip vice grips like knipex theve worked for me on more than one occasion
1983 Carina AA63 4age
Crucible
Real Life Mechanic
Re: Cambelt tensioner
Post by Crucible »
trueno_20v wrote:im changing my cambelt on my silvertop, ive got everything off easy as but the bolt that holds the tensioner on wont come undone ive broken a couple of sockets
Invest in a decent 3/8 set, go for 6point sockets (less chance of slipping), I cant imagine anything worse than tools not doing the job - instant loss of interest!
tnt
Post Reply
