my steering wheel rattles abit when im driving straight
Post Reply
agressor
Post by agressor »
bumps around bit but on straight tarmac roads, i dont think it always rattles but does quite a bit, also the steering alignment is out when i let go of wheel the car moves to the left abit, the handling has been getting weird aswell i think it might just be placebo effects but it feels like its handling worse, could this be that the front left tire is abit flat (not heaps) but more flat than the others or maybe my feels are about to fall off?
flat_0ut
Contact:
Post by flat_0ut »
wheel alignment??
AJz
Contact:
Post by AJz »
yeah, sounds like you need a wheel alignment man, that should fix it.
I had vtax :(
BlakJak
Contact:
Post by BlakJak »
Tyre Pressures need to be even, too. They'll cause drift...
Post by bluemaumau »
balancing, alignment is usually side ways movement, were as balancing cuz bumpiness.
i think 8)
Contact:
Post by KinLoud »
Could be an unbalanced tyre or an out of round wheel.
Maybe swap one front tyre to the rear if it feels the same swap the other one. This will help you to work out what wheel is the problem.
Ken
Ham
021 408 863
LEV_101
Post by LEV_101 »
can you checked your tyres ? can you see the metal things out ? :lol:
supraman_nz
Post by supraman_nz »
Had the same prob just a few weeks back , i got a wheel balancing done . it sort of fixed the problem but it ended up i had to replace the front tires as they had woren up evenly and then got an aligment. So any of thoes 3 could be the cause.
Post Reply
