Looneys new turbo :)
slighty_looney
Post by slighty_looney »
I just got my hands on a turbo thanks to trademe :) still got to get it posted down here so i dont have it yet but hopfully early next week it will b here, its a td04 off a NZ New GDB WRX that had travelled only 50,000ks
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
Post by Dell'Orto »
One day when it grows up, it hopes to be a real turbo :D
dotdog
Post by dotdog »
My starlet has a bigger turbo on it than that LOL
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
NILPSI
Post by NILPSI »
HAHA even my car has a bigger turbo than tha............ oh, hang on :P
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
slighty_sykotic
Post by slighty_sykotic »
lol, its bigger than mine.... well, its shiner than mine....
leave the td04's alone, they rock :D
*hugs his dead td04*
--Sykotic
NILPSI
Post by NILPSI »
slighty_sykotic wrote:leave the td04's alone, they rock :D
As paperweights :P
slighty_looney
haha come on td04s rnt that bad, atleast they spool quick :lol: its good for what i want anyway if i got a bigger turbo, id run more boost, then my engine would die
FC3S
Post by Dell'Orto »
Well actually, 15psi from a TD05 would be a hell of a lot less stressful on it than 15psi from a TD04 ;)
slighty_sykotic
But they so cute!
NILPSI
Post by NILPSI »
So thats what you guys are looking for in a turbo? something "cute" :?
I reakon my car would keep up with yours if you put a TD04 on it :P
Post by Dell'Orto »
I think an SC12 would be a better proposition :?
Post by bluemaumau »
Mmm, Boost wrote:Well actually, 15psi from a TD05 would be a hell of a lot less stressful on it than 15psi from a TD04 ;)
exactly, itll shit itself
slighty_sykotic
NILPSI wrote:I reakon my car would keep up with yours if you put a TD04 on it :P
Prove it next week then :)
On my 8psi on my td04 it will kill yours.
They arn't THAT bad if you don't overboost them.
Loudtoy
Post by Loudtoy »
No it won't, it might just beat it if your lucky, see the problem with the td04 is that while they are greate on 4efte's they aren't so good on 4agte's funnily enough because they spool so quickly, another thing about spooling quickly unless you got some weird stuff happening it's going to kill your top end power which is what the 4age's are geared for so imho don't waste anymore money on tdo4's find yourself a nice td05 or similar size turbo put that on at 8psi and be amazed at the difference.
BTW when i chucked a td04 at my missus old starlet had full boost by 3.2k rpm and had boost creep issues at about 4k till i got the wastegate ported so if your still running it with only the internal wastegate another thing to think about.
Oh lastly i hope you like your quick spool up time full boost by circa 2.3k but run out of puff at 5k doh. You won't see it so much on power graphs dyno etc but you will notice it on the road where it's still acclerating but just not as fast as down low till you change gears again
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
slighty_sykotic
wah?
Your serious... You think a blacktop will beat a a 4agte...even WITH a td04..
Seriously...
And its externaled, so no boost creep issues.
I releise that they arn't the best turbos, but its a street driven car, and they are cheap as hell.
--Sykotic
slighty_looney
yea its only for street use, for the price i got that turbo for, for that low k's its worth all the money i pay for it, im not planning on building a drag car just making my silvertop abit more powerful :D
FC3S
slighty_looney
and im sure the 2004 wrx it came off wasnt much of a slouch ever
FC3S
Post by Dell'Orto »
The 2004 WRX you got it off also had a decade of development and 400cc's over your car ;)
By all means, stick with the TD04...but you're seriously restricting what you'll be able to achieve.
Post by Dell'Orto »
slighty_sykotic wrote:wah?
Seriously...
--Sykotic
Its only gonna make 150fwkw MAX, and more than likely only around 130ish. The biggest advantage will be the good gain in low end torque.
why do you think the guy with the wrx got rid of it :wink:
Mmm, Boost wrote:but you're seriously restricting what you'll be able to achieve.
true that
Locked
