(Which is a 1983 AA60 Hatch, with 3AU BTW)
Original plans were to use my spare beams 3SGE engine, but lately I've been thinking that maybe something a bit different would be more fun.
I've already got a stupidly well handling NA car, I've been thinking perhaps its time for a stupidly poor handling turbo car.
Anyway, any suggestions, with pros/cons?
I'm looking for something fairly easy to fit, and not costing the world, but am open to sensible suggestions.
My thoughts so far:
3TGTE:
pros: Easy easy to fit, cheap to buy
cons: you cant get parts for them any more apparently, like cam belt tensioners etc. And they're all pretty old these days.
3SGTE:
pros: Decent power, easy power upgrade path
cons: they dont come in a RWD configuration, so are a PITA to fit.
4AGTE:
pros: Easy as to fit a 4AGE engine, not much harder to fit a turbo.
cons: Quite a bit of farting around, expensive if I want to start with a GZE block.
CA18DET
pros: RWD configuration, cheap as, reasonable power
cons: It's a nissan motor in a Toyota, I'd rather stick with Toyota if I could!
Driveshaft modifcations/custom mounts etc required too.
Hmmmm, any other suggestions?
Is there anything cheap, that will more or less bolt straight in for the meantime, that is a bit better than a 3AU? Like a 2TG or something? Preferably something that I could get with a bellhousing and engine mounts to suit the T40 and cross member already in the car.
Dave
