AE82 Dash lights disapeared?
Post Reply
KarlGti
Post by KarlGti »
Installed a head unit in my ae82 yesterday, didn't touch anything to do with the dash, but now I have no dash lights behind my speedo/tacho. Before I rip it all out is there anything obvious I should check? Can't find any blown fuses in the engine bay or kick panel, and I dont appear to have yanked any wires out from that area. Hmmm
AE101 Corolla FX GT | AE82 Corolla GT Sedan | AE92 Corolla GTi16
Mr.Phreak
Contact:
Post by Mr.Phreak »
Sounds like you've wired your earth up to the illumination feed.
Chances are your tail lights don't go either.
Check your fuses again.....but fix your wiring before replacing it.
SUBARUCONVERT
Post by SUBARUCONVERT »
yup u have earth'd out a dash light wire, u will have a blown fuse
THA SHZ
Post by THA SHZ »
b4 u check tht did u have the panel off under the steering column ? if u did and u have a dimmer switch then u mave have forgoton to plug it back in 8)
KarlGti
Post by KarlGti »
Yep I'm an idiot. Somehow had the ground wire on the head unit connected to the illumination wire. So with a bit of rewiring and a new tail light fuse all is sorted. Cheers for your help
Post Reply
