4a tps
- bluemaumau
- Toyspeed Member
4a tps
in the event that my tps is actually buggered,
are all 16v tps's the same?
surely they are if you use the same specs to calibrate them?
Where the $$% is that oil leak coming from /club
Stealer Of Souls
- Toyspeed Member
Physically they are different. Not sure if they differ electrically. I'll see if I can find out... Got manuals for both smallport and bigport.
'86 AE85.5 Levin
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
- kingcorolla
- Toyspeed Member
make sure you match the correct sensor with the right prong configuration. These prongs are interchangable but if you mismatch you will know about it.
some rest side to side and some rest up and down.
1983 Carina AA63 4age
- Caveman
- Toyspeed Member
- Contact:
IH8TEC wrote:i had to put my 4agze tps onto the na throttle body because my 4agze computer wouldn't run the na tps. so i bolted my 4agze tps straight on no problems
Must be differences in afm to map because my N/A map tps works perfect on the map gze ecu. Were the wires correct? might have to change the pins in the tps plug
AW11 Track Toy
Formerly known as 1998
i didn't look that much into it, the plug fit on, but the car would either barely run, or run like ass. had them both there so just put the 4agze one on there.
but i see what ya mean, how the map ones coiuld be the same, i have both at home, see what works best with the link.
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
- bluemaumau
- Toyspeed Member
bluemaumau wrote:it must be a afm/map differnce.
so bluetops and silvertops are afm correct?
what about bigport reds?
can anyone with a bluetop or silvertop post up the numbers,
greately appreciated
The Bluetops we get a MAP sensored, as they are Jap spec. I think the US spec ones were the only ones AFM.
Someone, correct me if I'm wrong.
Bigport Reds are MAP as well. I'll get the TPS number off my one.
