4ag quads
4ag quads
need to know a ouple of things.
1. differences between silvertop and blacktop throttle bodies?
2. can the silvertop throttle bodies be used in a map sensored setup?
thanks
thanks
Co-Founder of the Free Hotpooling Movement. $$% swimming. Just bask in the glory of free hotpooling.
Current Rides:
Current Rides:
and finally, will blacktop bodies bolt on to a silvertop manifold?
Current Rides:
Current Rides:
i heard 38 and 39 lol
im not overly worried about the size, more the fact that i will be able to seperate them to run on a 6 cyl engine. and also use them in a map sensored environment
Current Rides:
Current Rides:
The Silvertops are 43mm and the Blacktops are 45mm. The measurements are the butterfly size. They both have a bit of taper in them.
You can bore the Blacktop quads out to a 50mm butterfly, but I would imagine it wouldn't have any taper after that.
As for bolting the Blacktop throttles to a Silvertop manifold, yes you can. BUT. The ports are way different, so you'd need to get it matched. The throttle linkages are set up differently on each of them too.
The Blacktops have a vacuum accumulator, as they are MAP sensored from factory, this gives it a smoother vacuum reading at idle and high vacuum driving.
You can use Silvertop quads with MAP sensor, but it's best to make up a vacuum accumulator for them as well. Don't take the MAP sensor vacuum from a single runner, that is bad!!! OK....
Crampy wrote:The Silvertops are 43mm and the Blacktops are 45mm. The measurements are the butterfly size. They both have a bit of taper in them.
cheers dude! exactly what i was after
Current Rides:
Current Rides:
- soopachargen
- Toyspeed Member
- Contact:
just for the sake of arguing there's a guy on mr20c that claims to be running quads on a 5sfe with standard computer...
When in doubt, down and out.
with an AFM set up, there is no real reason why quads couldn't work with a factory ecu.
RomanV wrote:What about TPS signal? as you've effectively increased your throttle body area massively... 5% open throttle is a lot different between the two, in terms of cross sectional area.
I agree. Having four 45mm throttle is equivalent to a single 90mm throttle, area-wise. (although there are also other factors which will change the tune as well.)
- soopachargen
- Toyspeed Member
- Contact:
i thought (read thought) that with ITBs that its different as you only have one throttle being sucked through at a time???
- soopachargen
- Toyspeed Member
- Contact:
will be using aftermarket ecu. there is no reason why you cant convert to quads on standard computer. you may need to add a few bits in somewhere in the loom to trick the ecu into thinking its running one. but its do-able.
im opting to use a link/similar purely to accomadate the cams and fueling aswell.
Current Rides:
Current Rides:
That isn't quite how it works though. Think about this. a GTiR SR20DET runs 4 x 45mm throttle bodies, 1 in each runner. Yet most other 2 Litre turbo engines runing a single 60mm throttle body.
Back in the days of carbies, to make a hearty 2 litre rev to 8000-8500 a pair of 48mm side draft carbies were the go, However if you put a single 90mm carby throat onto that motor it'd be a sack-o-sheit.
Throttle bodies at different stages of the manifold/inlet tract require different sectional areas and therefore different flow rates to achieve the same actual engine inhalation CFM.
Can you grasp what i'm saying?
