Automotive bolts
Automotive bolts
Where do you guys get bolts etc for cars from?
You can get the standard high tensile bolts from mitre 10 etc but they all have larger heads (size 19 rather than 17) etc and when trying to fit them in next to a bellhousing or something you cant get the damn socket in because its too wide!
PICS UPDATED DAILY
- rwd_mayhem
- Toyspeed Member
repco and supercheap stock them but they are crazy expensive, like 9$ for 4x m8 bolts
speciallist stuff like flywheel bolts and maybe bellhousing sets often come in kits from the manufacturer.
also there are fastener and bearing places such as schrodoco which usually have a better selection.there are a couple of places in welly too but dunno if thats much used to you. look in your local phone book or whatever for fastener speciallists and you should find something in your area. they are usually cheaper and more helpful too, as ive gone there looking for odd stuff sometimes.
i think automotive bolts are usually 1.25 thread, but couldnt confirm that without checking.
Yeah they are 1.25 thread.
PICS UPDATED DAILY
- Dell'Orto
- ** Moderator **
flygt4 wrote:repco and supercheap stock them but they are crazy expensive, like 9$ for 4x m8 bolts![]()
Yeah those packs are thievery, Bay Engineering will sell you a bunch for less.
your local dismantler should have a 'bucket o bolts' you can hunt thru for free or a small price
- bluemaumau
- Toyspeed Member
- fj40cruzapete
- Toyspeed Member
- Contact:
- Silent Knight
- Toyspeed Member
- Contact:
Engineering supply stores, thats where i pick all my bolts up from, cheap as chips, especially if you can suss a discount
Just remember though, engineering stores generally only sell grade 6 or 12 in the 'high tensile' range, and grade 12 isn't cheap! automotive uses grade 9, and only specialized automotive engineering type stores seem to carry them, so most the time you got to toss up whether grade 6 is going to cover it or if your going to have to fork out the big bucks for the 12s!
grade 12 fine thread.... so $$% expensive!
