4age 20valve - Cambelt Tensioner (idler tensioner)
Post Reply
Zyros
Post by Zyros »
Hey all, just putting on the waterpump, and doing the timming on my engine.
On the idler bearing, (cambelt tensioner), whats goes into this hole..
4age 20valve silvertop ae101.
Top right ;)
Obviously the little holes for the spring, middle is to bolt the tensioner on.
The other hole where it connects to the block has no thread for a bolt.
Contact:
Post by matt dunn »
It's on upside down.
there is a part on the oil pump housing that goes in there.
Zyros
Post by Zyros »
matt dunn wrote:It's on upside down.
Sorry, i should of said that the photo is from google as an example.
Just wanting to know what goes through that hole to pivot it.
the part on the oil pump housing the bolt hole lines up to, doesnt have nethn in it.
Contact:
Post by matt dunn »
it is not a bolt hole, there is no thread, it's just a locator dowell that is there for it to pivot on.
Zyros
Post by Zyros »
Ahk, well i dont have nething in that hole at all for it to even pivot on..
Just a blank hole which lines up with the bearing?
Do i leave it? Or am i pissing something which goes in there which i can buy?
Contact:
Post by matt dunn »
There needs to be something there for it to pivot on.
85AW20v
Post by 85AW20v »
And it might have dropped down around the crankshaft pulley somewhere. Have a good look around before putting it all back together. You don't want the dowel jamming things up.
See ya
Simon
85 MR2 20v
JRS
Post by JRS »
the dowell will be there. the tnesioner in the image is installed backwards.
the fange witht he holes should eb facing the motor.
the dowel only sticks out 3 or 4 mm. it's highl unlikely that it's not there.
take a photo of your motor and post it here.
meh.....
Zyros
Post by Zyros »
Ill get a photot hopfully tomorrow, mine is on correctlly, its just that where the bearing lines up, its just hole, theres nothing comming out of it to pivot on, a hole which goes in about 1cm, no thread.
Post Reply
