simota heat shield?
simota heat shield?
hey guys.
do you think the simota heat shield for my pod filter will actually stop hot engine air from being sucked in? obviously a cold airbox is the better option but its a mission and im thinking i could just buy this heat shield.. clip it on and problem solved.. what do you guys reckon?
p.s. bought some 15" mags for my car today.. just waiting for them to arrive. will post a pic when i get em on.. churr
- touge rolla
- Toyspeed Member
- Dell'Orto
- ** Moderator **
Hows it gonna stop hot air being sucked in? It only covers half the surface.
- ~SlideWays~
- Toyspeed Member
- barryogen
- 2ZZ Guru in training
- Contact:
it would stop/slow radient heat, but I wouldn't think that radient heat would be that much of an issue with a pod
The intakes on cars suck so much air through them that they are sledom higher than ambient anyway... although if they are sucking straight from the engine bay, ambient is 50c+
dave.net.nz
Project "Better Altezza" - Dave Style
http://forums.toyspeed.org.nz/viewtopic.php?p=659132
Comments
http://forums.toyspeed.org.nz/viewtopic.php?p=659134
Comments
- ~SlideWays~
- Toyspeed Member
Way back when i had my FX with 4age in it, i fitted a pod filter, noticed a significant drop in fuel economy, as it was sucking alot of hot air.
Replaced the it with the factory box and K&N panel filter, and my fuel economy improved quite a bit.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01 wrote:Way back when i had my FX with 4age in it, i fitted a pod filter, noticed a significant drop in fuel economy, as it was sucking alot of hot air.
Same with Skyline...
Put a pod on it.. Bye bye fuel.
