Starter Motor Location
darkman0101
- Toyspeed Member
Ok, can someone describe where exactly I should be looking for the starter motor on an AE92 FXGT?
I spent a bit of time between the rain yesterday looking for it - about the only place I didn't look was under the air filter box.
Have a strange intermittant fault where I turn the ignition and nothing happens. Voltage drops but nothing from starter motor. Not the battery as stereo, lights etc are fine at the time.
A couple of turns of the key and it'll usually fire.
Guessing it might be a connection on the starter motor - just got to find the freaking thing...
- rollaholic
- Toyspeed Member
- Dell'Orto
- ** Moderator **
^ happened on the old man's AE92
Dodgy starter throw solenoid? It happens on supra's all the time and you its because the old wiring causes too much of a voltage drop by the time the juice gets to the solenoid. You have to rig up a relay system
Just a thought.
Just a thought.
Id say it could be the stater cranking signal to the ecu thats faulty. Its a little wire that goes to the starter and always comes loose.
PICS UPDATED DAILY
its comon for ae82's and ae92 because of the heat produced from the exhaust manifold to die faster. they try to start but dont and makes it sound like the battery is flat, wait a sec or 2 and try again and it starts up.. you will probably need a new or recondition it soon. its under the exhaust manifold gearbox side.
Toyota Trueno AE85 Turbo
