Unrelated Toyota question. But my daily driver(99 hp11 primera, sr20de) didnt want to start yesterday am.
towed it to the mechanics workshop and he said it no compression . The car was running perfectly normal the night befor and does not use any oil or lost any water doesnt smoke or any thing.
Any way got the car running and its been sweet today and has normal compression.
Any idea's. Ive actually sold the car and the guys picking it up tonight I just dont want the dam thing to come back bite me in the arse.
Jordon
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
They dont have the same issues as the early SR20's with oil feeds to the cams blocking do they?
1988 KE70 Wagon - Slowly rusting 1990 NA6 MX-5 - because reasons 2018 Ranger - Because workcar 1997 FD3S RX-7 Type R - all brap, all the time OMG so shiny!
the later P11 & U14 SR engine usually run big ends, they dont have oil squirters onto the cams like the earlier ones do.
I know what can cause that sympton after someone has done engine work on them but if its been driving then just turned off, it cant just mysteriously develop it. Very odd
If it happens again, few squirts of oil down each spark plug hole and take it for a drive it until the smoke goes away (100m-ish). Have had a few do it, bit of oil get compression back up and they usually go first pop. Not sure what sticks, but they're always good as gold after.
I have come across that a few times with sr20s, sr18s cranking and sounding like its thrown a cam belt and no compression (yes I know they are chain drive). Weve had the same issues with later Jaguars also, but as suggested above, pull the plugs and squirt oil down the bores, cough and splutter, then they kick into life eventually.
it seems to be more common problem with the nissans when they have been flooded or have sat around for days on end.
if u selling it, write up as is where contact, say good by make sure its hot when they pick it up.
see them at work from time to time, i've had to put my boot into crank it for 1min to get them going. no longer or u will flooded engine with fuel if plugs arean't already dripping. and will damage the starter.
