Help with brakes, any opinions...
- trd-drifting
- Toyspeed Member
I am not a mechanic, but under hard braking my supra pulls slightly to the left not to noticable but would like to correct this. How would you go about fixing this, as my understanding is that the left brake will be working well or to good and right brake not good enough or a bit of resistance in the pistion etc.. How would you go about correcting this as this is hardly noticable but i want corrected.
Any opinions appreciated
Josh
Josh
- trd-drifting
- Toyspeed Member
Are supra's sliding type or solid calipers?
Does the caliper have pistons on both sides or just one?
If you rule wheel alignment out (and sliders), I'd start with a good brake bleed, then if that doesn't fix it you would want to look at re kitting the calipers (assuming the proportioning valve only splits front and rear?).
- trd-drifting
- Toyspeed Member
Sorry about replying late to this
Single pistion calipers (usless things)
Also talking front brakes sorry.
I will start with a brake bleed and replacing fluid this weekend, if it is the seals gone in the caliper if i pushed the pistion back into the caliper should one be hard to push in than the otherside and would i notice the difference if i was using a small G clamp, or is this a stupid idea. Any thing else i could check before i do it this weekend.
Other than checking for obvious small hose kinks then i will rekit the calliper. Or is there somthing else i am missing.
Josh
Josh
The seals don't fail to often I've found, but what usually cause an issue like this is the piston of the caliper getting seized with a rust build up around the seal area.
So yeah if thats the prob it will be hard to push in or even move.
I'd rekit them and with new pistons as well. The kits usually dont cost much but that last dust seal that goes on the end of the piston is a biarch to get on. Make sure you get some brake assembly/rubber grease when you buy the kit cause it makes the rubber slide over the piston better and less chance you will tear it trying to get the bastard on.
Adoom wrote:I'd rekit them and with new pistons as well. The kits usually dont cost much but that last dust seal that goes on the end of the piston is a biarch to get on. Make sure you get some brake assembly/rubber grease when you buy the kit cause it makes the rubber slide over the piston better and less chance you will tear it trying to get the b**tard on.
Any idea's roughly what the rebiuld kit's worth? And where you get it from?
lucasthefallen
- Toyspeed Member
- 1I1
- Toyspeed Sponsor
- Contact:
cat007 wrote:Adoom wrote:I'd rekit them and with new pistons as well. The kits usually dont cost much but that last dust seal that goes on the end of the piston is a biarch to get on. Make sure you get some brake assembly/rubber grease when you buy the kit cause it makes the rubber slide over the piston better and less chance you will tear it trying to get the b**tard on.
...Toyota kits retail for $76.50
TRD Clicky >>Here
mark@manawatu.toyota.co.nz (Please mention Toyspeed
TRD Clicky >>Here
- 1I1
- Toyspeed Sponsor
- Contact:
cat007 wrote:per corner I assume??....
For front pair
TRD Clicky >>Here
TRD Clicky >>Here
- rollaholic
- Toyspeed Member
- Dell'Orto
- ** Moderator **
Yeah most genuine parts have come down in price, they had to really. That said, if you want something that isnt fast moving, thats where they make their margins again
I think TGP kits don't come with pistons, so if your piston/s is scored or pitted etc then you would need to buy new pistons too.
Of course you won't know till you've pulled it apart, or you could go on the safe side and get pistons when you get the kit and do them anyway (I would depending on cost).
rollaholic wrote:must say genuine parts seem to get more competitve by the day, specially for toyotas. tis awesome to see!
the kit i got for my 101 was about that price i think, but they only have in them a couple of rubber boots, a small bag of pink brake grease and a couple of the round boot clips, so really, they're not doing too badly out of it
