over torqueing
TRD_ZERO
over torqueing
Post by TRD_ZERO »
OK so i made abit of a blunder how serious is it if i overtorque the head it was supposed to be 22ft-lbs when i made it 30. Should i just leave it? pull the headstuds out and redue it?( they might be abit stretched now though). Its a blacktop if it matters.
evil_si
Contact:
Post by evil_si »
ok was it 30ftlb on its own or are they torque turn as well?
the torque spec of 22 should have a +/- figure or percentage, do you know what that was
Contact:
Post by Mr Revhead »
22ft-lbs is just the first step
take them out and do it again
with the 20vs you torque them, then do another 90 then 90
so 30ft-lbs wont have over torqued it
are you using new bolts?
TRD_ZERO
Post by TRD_ZERO »
yes im using new bolts i torqued them to 30 ft-lbf then 90 then 90 again. So it will be ok to take them out and do it again, they wont be stretched? the book says 22 ft-lbf thats foot pounds right?
Grrrrrrr!
Post by Grrrrrrr! »
Not sure whether you will get away with leaving them in, but if you do take them out its bin time for those headbolts. Do not re-use torque to yeild bolts.
TRD_ZERO
Post by TRD_ZERO »
evil_si wrote:ok was it 30ftlb on its own or are they torque turn as well?
NO it doesnt have a +/- on it just straight up figures
85AW20v
Post by 85AW20v »
There is a specific range regarding length that the bolts have to be within. As I understand it, if they are within the range they can be reused. Standard length is 114-115.00mm. Maximum length is 116.50mm.
See ya
Simon
85 MR2 20v
jondee86
Post by jondee86 »
Leave them be... don't worry... be happy :)
Cheers... jondee86
Watch this space >>> <<<
TRD_ZERO
Post by TRD_ZERO »
ive asked around and im getting mixed responses, im getting a few people saying i should just leave them they will be fine. What could happen to them?
Contact:
heres some info
http://www.acl.co.nz/Tech/Torque%20To%20Yield%20Headbolts.pdf
after reading that, I'd changing them...
levinguy
Post by levinguy »
seriously due to the hassle of what could happen, i would just replace them, is it really worth risking it?
TRD_ZERO
Post by TRD_ZERO »
levinguy wrote:seriously due to the hassle of what could happen, i would just replace them, is it really worth risking it?
You are right ill get some new ones then.
Contact:
Post by Bazda »
or get some arp heas studs.
NZ_AE86
Contact:
Post by NZ_AE86 »
I'd leave them in, they will be just fine.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
TRD_ZERO
Post by TRD_ZERO »
I went to an engine reconditioner today and asked them they said it should be fine and i should just leave them.
pc
Post by pc »
I reckon it'll be fine.
I over torque all my headbolts a little bit anyway, haven't had a failure yet.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
fangsport
Post by fangsport »
pc wrote:I over torque all my headbolts a little bit anyway, haven't had a failure yet.
a wee bit of extra squeeze won't hurt, no worse than going 95 then 95 degress on rotational torque.
on a good day, might even sqaush the gasket more and bump the compression slightly!!!!
TRD_ZERO
Post by TRD_ZERO »
Im hoping it was a really good day.
MAGN1T
!USER HAS BEEN BANNED!
Post by MAGN1T »
It's only an intermediate step, doesn't matter. The purpose of the intermediate steps is to ensure the bolts are done up evenly.
As for the link.
I don't understand how putting a 10mm bolt into a 10 mm hole (in a block & head) is going to save any significant weight over a 12mm bolt in a 12mm hole.
Strange logic.... sure the bolts are lighter ...what about the holes?
Sure , steel bolts, aluminium head but?
Don't believe everything you read.
Steve
Computers make you go mad.
Post by Dell'Orto »
I know if Henry from ACL wrote that, I'd believe it over anything you type on the internet Steve ;)
Post Reply
