I have just aquired an AE92 Corolla GT Sedan and i'm about to embark on a long journey to getting it immaculate as it once was.
One of the first things I am tackling is the suspension,
Are the shocks and springs a straight bolt on between AE92/101/111? Obviously the springs will be a different rate as the cars do not weigh the same but I wanted to make sure that I could fit shocks from a later model Corolla into mine.
Thanks in Advance.
Phil
Suspension Compatibility [ AE92/101/111 ]
[WAAA] - 98' JZX100 Chaser Tourer V
- rollaholic
- Toyspeed Member
I tried this with an EE90 corolla hatch and AE110 corolla. I assume the AE92 and EE90 are similar suspension wise.
What I found
front suspension: the ee90 uses heavier swaybar and softer springs than the ae110. The whole ae110 leg will bolt into the ee90, but it will sit really high in the front. the shocks are interchangeable though. I couldn't swap over the whole suspension subframe (can't remember how they were different, only that they were)
rear suspension: the rear spring diameters were different at the base. iirc, I couldn't swap over the whole leg either
What I found
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
'92 SW20 GT-S
'91 GT Legacy wagon
- Toyspeed Member
- Contact:
They are all interchangable between these models.
Only the brackets for brake lines etc are different.
- rollaholic
- Toyspeed Member
- Mr Revhead
- SECURITY!
- Contact:
rear struts are different overall lengths, wont be an issue unless your using the longer ones (ae111 iirc) and lowered springs, anything more than 30mm lower and you may have issues
and i think the ae92 lower spring seat is different, wont fit ae101 onwards springs
and the aforementioned brake hose bracket
I was talking about swapping the whole suspension leg over. Not springs etc.
I'm just saying they will all bolt up to the car and work. Maybe you cant interchange parts though.
