bassicly a simple answer is all thats req
just asking wether a quad throttle setup off a 20v 4age will fit the 16v 4age along with will the ecu run it in a ae92
im pushing my luck i think
cheers guys
sam.
fitting qhuads to 16v 4age?? yes or no
021-0290-7728
- Mr Revhead
- SECURITY!
- Contact:
- rollaholic
- Toyspeed Member
- rollaholic
- Toyspeed Member
FULLOC wrote:would smallport ecu be able to run it? ie just tuck the map out of the way?
im sure fitment wouldnt be too hard
depends on what you mean by run, it might run but probably worse than with standard intake.
need 20v ecu or aftermarket, the vac created by quads is different to a vanilla intake so getting it to idle properly in particular is a problem.
bit of a search should unearth plenty of info for interested people
- QikStarlie
- Toyspeed Member
- Contact:
