Have my valves hit my pistons..
Havn't got the answer I've been after on the silvia forums but its a fairly generalised question. My cam chain skipped a few teeth, engine runs but poorly. If say my valves did make any contact with the pistons you surely would be able to feel it by manually winding over the engine right? Ie when i reset the timing with a new tensioner etc she should be fine?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
FULLOC wrote:reset timing and find out...
Easier said than done, anyone ever had to replace the chain on a nissan sr20? Still in the process now, the sump and the cam gears have to come off to get access to the front cover plate bolts along with all the other shit around it
Its skipped about 4-5 teeth, stressen out if its going to be sweet or not? Was running after it slipped but badly, no unusual sounds though.
HRT wrote:Could whip the rocker cover off and make sure the valves are all sitting up at the same height
Yeah still hard to tell aye
lucasthefallen
- Toyspeed Member
- rollaholic
- Toyspeed Member
rollaholic wrote:tough to do a leakage test with no cam chain
buy a toyota imo
Still does have the chain on, just slipped around a few teeth. Yeah bring back the 4ages with the non-interference heads
- rollaholic
- Toyspeed Member
- Mr Revhead
- SECURITY!
- Contact:
Mr Revhead wrote:how did it skip a few teeth?
When replacing the hydraulic tensioner, when the chain slackened must of slipped or something. SR chains often like to rattle as the tensioners like to play up sometimes
Sounds odd... I replaced an SR18 head once and from memory the hydraulic part was only to hold the tension. There is a catch system on the tensioner to stop it completely slacking off, was it broken?
Can you see enough of the tops of the pistons down the sparkplug holes to see if there is any surface damage? Maybe a tiny mirror & an LED on the end of a wire will let you see enough.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
Manfield - 1:24s
Take the rocker cover off and check the clearances between the cam and the buckets. If the clearances are easily visible then you know something is wrong.
Also if the chain needs replacing which sounds like the case, then turn the cams over by themselves (if its possible) to see how tight the valves are
1990 ST185H - project
1996 VS Acclaim wagon
pc wrote:Sounds odd... I replaced an SR18 head once and from memory the hydraulic part was only to hold the tension. There is a catch system on the tensioner to stop it completely slacking off, was it broken?
The chain did completly slacken off unfortunatly. Tryed to look down the spark plug holes but dont want to risk putting anything down there just in case in falls off n I then have to take the head off.
