help mechanics of dunedin
shihad
Post by shihad »
my 85 4age trueno is leaking oil from somewhere and im unsure where for some beer of your choice please come and diagnose my problem :lol: .the car is in north dunedin. cheers
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
rwd_mayhem
Post by rwd_mayhem »
degrease the whole thing, run it for a bit and then look where it is coming from, it should be easy to see once its nice and clean.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
Post by Lloyd »
4AGE is likely to be rocker cover gasket or distributor seal/oring. Clean up around those and see where the leaks coming from. Failing that, front seals if its at that end of the engine, or the rear main if its coming from between the engine and gearbox
shihad
Post by shihad »
interesting must be the rocker cover gasket and distributor seal so far but i dont think that explains why its on the alternator as well unless its landing on the belt and throwing the oil on to the alternator lol i will get some degrease 2day.
Post by Lloyd »
The stuff from Supercheap used to be $2-something a can and was actually pretty good stuff. Assuming they still do it cheap
shihad
Post by shihad »
it appears oil coming from the front of the motor just above the sump i cant see where its coming from and out of spark plug number 2 lol
JT
Contact:
Post by JT »
shihad wrote:it appears oil coming from the front of the motor just above the sump i cant see where its coming from and out of spark plug number 2 lol
It's not a big deal coming out the front, just annoying. How long till cambelt needs doing? Have to pull everything off to do seals so just do them when you do cambelt. Oil around spark plugs is probably just run off from not getting all the oil in the filler hole :wink:
shihad
Post by shihad »
some was run off but when you run the motor it bubbles over the number 2 lead.was told motor was rebuilt recently so not 4 another 100km lol now i know why the guy told me to run shit oil haha.i drove down from gisborne oil was fine in hawks bay but could have developed the leak anywhere after that.after arriving in dunedin the next day i noticed a puddle of oil under the car checked oil and there was nothing so im praying that it had enough on the way down.
note after thinking about it some more it would have almost certainly been leaking on the way down and would have leaked the last of the oil when i parked up in dunedin as it was parked on the 4th street hill leaning forward.
cozmoid
Contact:
Post by cozmoid »
bummer bro. Hope it's ok.
Ae70/Te71 Hybrid
viewtopic.php?t=54364
shihad
Post by shihad »
yea sounds like it has a tick or a knock im not sure maybe i have %&($&ed it.maybe im hearing things
cozmoid
Contact:
Post by cozmoid »
get someone u know to check it out. If not damien at graham page engine reconditioning is a toyota freak and would be able to give u a good idea by looking at it.
Ae70/Te71 Hybrid
shihad
Post by shihad »
cheers will do
shihad
Post by shihad »
car is now at graham page engine reconditioning needs a new cambelt due to the oil all over it.the guy there said it could be the o ring around the oil pump.sigh my wallet will not be happy :oops:
Contact:
Post by Bling »
Look at it this way.... it will be happier than if the belt had slipped :lol:
rolla_fxgt
Post by rolla_fxgt »
BZG|Bling wrote:Look at it this way.... it will be happier than if the belt had slipped :lol:
There always has to be one optimist doesn't there. I bet you'd still find a positive if an asteroid hit the earth :lol:
But sucks to here dude, hope its fixed soon, and isn't too much of a drain on the ol wallet
Stott69
Post by Stott69 »
at lest the boy racer problem would be solved?
Image jzs147 Aristo money pit
Post by Lloyd »
Boyracer problem?
Stott69
Post by Stott69 »
the astaroid
barryogen
2ZZ Guru in training
Contact:
Post by barryogen »
man we have bad humour...
cozmoid
Contact:
Post by cozmoid »
shihad wrote:car is now at graham page engine reconditioning needs a new cambelt due to the oil all over it.the guy there said it could be the o ring around the oil pump.sigh my wallet will not be happy :oops:
Hey bro . I was talkin to the mechanics at graham page today. Sounds like you have a pretty sweet little ae85 :) Show us some pics. Im glad you took it to them as well as it sounds like ur car will be sorted nice an sweet. He was sayin the rattle will be easy to fix too :) Rwd for life :)
Ae70/Te71 Hybrid
Post Reply
