TRD pistons
doublezero
- Toyspeed Member
TRD pistons
Hey guys,
I looked around the forum but couldn't find anything on pistons. Hopefully everyone can chip in and pass their knowledge to me.
I was looking at these TRD pistons and they have a high compression of 13.0
http://trdparts.jp/english/parts_engine-2zz-ge.html
Will 98RON be good enough these bad boys ?
cheers guys
cheers guys
No - I think 13:1 pistons would need avgas and an aftermarket computer.
98 octane is almost a bit low for factory 2zzge engines (would run on 100 in Japan)
What are you wanting to achieve with your motor?
Ken
AUck
021 408 863
Ken
AUck
021 408 863
doublezero
- Toyspeed Member
- Adamal
- Toyspeed Member
Yea, 13 is a bit high. It MIGHT be alright if you run a thicket head gasket to drop the compression a bit, but you wouldn't be wanting to give it any load at low RPM.
- Adamal
- Toyspeed Member
I thought that if you drop the compression ratio, then it would decrease the chances of preignition.
Being that when you compress a gas, the byproduct is heat, and this is what causes detonation with a low octane fuel.
- Dell'Orto
- ** Moderator **
Yeah 13:1 wouldn't really be feasible on pump gas, maybe if you backed the timing right off but what would be the point?
Adamal wrote:I thought that if you drop the compression ratio, then it would decrease the chances of preignition.
It affects the squish area that basically affects how well the heat is spread and with impeded squish area you have more high temp. spots which increases chances of pre-ignition. Basically all the R&D that toyota did with combustion chamber goes out of the window when you use thick head gasket. It is kind of counter productive to have 13:1 pistons, then to lower it back to 12:1 (or whatever is stock) and increase the chances of detonation while decreasing the power (due to lower efficiency of combustion due to not enough squish) and fuel economy.
doublezero
- Toyspeed Member
doublezero
- Toyspeed Member
lol I just saw on the trd parts website that the pistons could be put in with the simple mods to make some good gains. It would be a street car with the occasional track time.
All I was asking was whether the compression ratios would work with our pump gas.
I apologise that a simple question would create such a mocking.
Thanks for all those that answered my question. It is deeply appreciated.
- Adamal
- Toyspeed Member
Mr.Phreak wrote:Adamal wrote:I plan on making a 10 second car. What would I need to do?
Buy a 20v
I said a 10 second car. I don't think I could handle a 5 second car.
doublezero wrote:All I was asking was whether the compression ratios would work with our pump gas.
Fair enough with the comments, but all the time people post up giving only half of the required information and people can't give the best possible advice. Its for your benefit we make you provide more information as people on here know a LOT about building powerful engines etc.
So it would be better to ask if its worth just changing pistons for a performance gain etc. Could save you a lot of money in the long wrong spent on the wrong mods. There are many ways to get gains from engines, each with different potential gains etc,
Just my 2c
Malcolm wrote:Dell'Orto wrote:Yeah 13:1 wouldn't really be feasible on pump gas, maybe if you backed the timing right off but what would be the point?
Our car runs 12.5:1 with up to 14psi of boost, no intercooler, on pump gas. It's all in the tune (well, a lot of it is).
Very normal for diesel engine, amazing for petrol...
