Caldina GTT Cam belt
Post Reply
Lac
Post by Lac »
Hey,
I know its been asked a bit and i have done the searching but just want to confirm when i do the cam belt change. Im coming up to 90k so going to get it done next service. I want to make sure i do it right the first time.
Caldina GTT
Cam belt
Tensioner pulley
auto tensioner
idler pulely
all seals (2x cam 1x crank 1x oil pump)
water pump
tensioner bolts
thermostat
Anything else?
Caldina GTT Sydney
jaypines
Post by jaypines »
dont forget the o-ring behind the oil pump... these can leak over time. inspect drivebelts as well.
Lac
Post by Lac »
Can you get the the timing belt replaced in a kit? That comes with all the parts together? Any one know a toyota part number?
Lachlan
Caldina GTT Sydney
1I1
Contact:
Post by 1I1 »
Toyota sells all the bits you need separately..
TRD Clicky >>Here
Warren
Post by Warren »
Did you do this in the end?
Just out of curiousity, how much did it cost you?
Mr. T says "Don't do school, stay in milk, and drink your drugs"
Lac
Post by Lac »
Yer i did actually, big thanks to Mark. Total cost was 399.10 plus GST,
Caldina GTT Sydney
Warren
Post by Warren »
Lac wrote:Yer i did actually, big thanks to Mark. Total cost was 399.10 plus GST,
Awesome, was that for everything? (Cam belt, Tensioner pulley, auto tensioner, idler pulely, all seals (2x cam 1x crank 1x oil pump) water pump, tensioner bolts, thermostat etc etc)
Lac
Post by Lac »
Yep everything
Caldina GTT Sydney
Post Reply
