Hey all
I'm currently running an earth cable from my battery in the boot to the top of the rear strut tower - which I don't think is perfect, especially for things like the ECU and Wideband sensor, as they require pretty solid grounds....
Is it worth running an earth cable to the front? And if so, where should I go to get some welding cable? I'm on the North Shore.
Hunt
Where to buy welding cable in Auckland/North Shore
- XS1V
- Toyspeed Member
- Contact:
Yup BOC on Porana is good
Got all the crimp ends etc as well
Brad
Brad
ST205 Group A Rallye #2363
XS1V wrote:Yup BOC on Porana is goodGot all the crimp ends etc as well
Brad
Ah yep - rummaged through sergei's posts and found the one where BOC was recommended. Will pay them a visit today!
Thanks guys
So on the tech side of this, is it actually worth running an earth cable from one end to the other of a car? Or does the car shell provide a good enough 'transfer' of the earth from one end to the other? I would have thought so long as you go to bare metal for all the earths it would be fine.
BZG|Bling wrote:So on the tech side of this, is it actually worth running an earth cable from one end to the other of a car or does the car shell provide a good enough 'transfer' of the earth from one end to the other? I would have thought so long as you go to bare metal for all the earths it would be fine.
I would have thought so too.
sergei wrote:Don't run earth cable. It is counter productive. Best earthing is to the chassis (just make sure it has good contact).
Roger that - I'll clean up the main earth contact point and use a better quality connector.
