Thought about blow off valves
Random thought id like to open up for discussion
if you were to take a turbo car with a blow off valve that has a feedback into the intake and then move the feedback to feed into the exhaust manifold would it create anywhere near enough air pressure to assist with spooling the turbo quicker between changes and make the car faster in anyway or would it be a complete waste of time?
The GT4 is to Celicas what the GTR is to skylines.
- Santa'sBoostinSleigh
- ** Moderator **
- Contact:
I would imagine you'd end up just heating up your intake
couldnt see it helping at all
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
- Luke - BZG
- Toyspeed Member
- Contact:
- Dell'Orto
- ** Moderator **
And possibly the exhaust gas would push back through the path of least resistance aka the small low pressure feed
- ** Moderator **
- Contact:
but the air that is blown off is on the intake side of things is it not, so if that was plumbed to the exhaust, heat would travel back up the plumbing to the intake
Santa's Mega Sale
Re: Thought about blow off valves
LEAKER wrote:... a complete waste of time
As I see it, you would get not enough air and it would be at the wrong time.
The pressure difference would also probably be wrong and you would get exhaust going backwards through the BOV instead of the excess intake charge going out. Shit you don't want hot would end up getting hot. You would be better off hooking some compressed air or something up to the exhaust housing to spool it up faster when you mash your foot down. Not sure that would work either.
- tsoob
- Toyspeed Member
- Contact:
Adoom wrote:LEAKER wrote:... a complete waste of time
its called nitrous oxide.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
On the ST205 Group A models, there was a system similar to what you describe, as part of the non-functional antilag system. I'm not certain whether the purpose of this additional air was to provide some cooling to the exhaust components to mitigate some of the premature failure of components that antilag can cause, or whether it was to provide fresh air to help the fuel combust in the exhaust runners to make the system more effective.
by using the plumb back in the standed setup you are basicly doin what you want to do any way as the rush of air going into the intake from your valve before the turbo has only two ways to go, out the intake/ airfilter against the flow of air and/or down the intake towards the turbo with the flow of air, as it goes towards the intake of the turbo compressor it has muchly the same effect as going into the inlet of the turbine (its still pushing the turbo around in the same direction)
however haveing the air push your turbo around via the compressor isnt as efficient as pushing it via the turbine because of the shape of the vanes its still going to be better than disrupting the exhaust gas flow and possibly haveing exhaust gas push its way into your intake
girl: can I trust you?
me: you can trust anything
- h8wrxs
- Toyspeed Member
- Location: travelling to candy mountain with my magical leoplurodon
Malcolm wrote:On the ST205 Group A models, there was a system similar to what you describe, as part of the non-functional antilag system. I'm not certain whether the purpose of this additional air was to provide some cooling to the exhaust components to mitigate some of the premature failure of components that antilag can cause, or whether it was to provide fresh air to help the fuel combust in the exhaust runners to make the system more effective.
i think some of the evo4s onwards had a similar setup? dont think it worked very well though
The four seasons in Australia consist of "$$% it's hot", "Can you believe how $$% hot it is?", "I won't be in today because it is too $$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
and if you take the ST205 WRC blow off valve, it actually has 2 halves, a really complex system if you ask me, and IMO it's to provide fresh air for the badadadadadada VROOOOOOOOOOOOOOOM!
- rollaholic
- Toyspeed Member
VR-4Squid wrote:CelicaGT8 wrote:AFM has registered the air coming in, and if it wasn't there it would make it run rich for a split second?
Throttle is closed, engine rpm is (way) above idle, therefore fuel injected = zero.
Internet/magazine myth #2296 debunked.
not true. Take 1 Series 4 or 5 rx7, vent the BOV to atmosphere = flamage on gear, for this exact reason.
