Indicator speed and WOF
- Adamal
- Toyspeed Member
Does the speed of the indicators have an impact on WOF?
Since changing indicators, they flash like buggery, even though all are accounted for.
If they do this, would this be something it could fail a WOF for?
http://www.nzta.govt.nz/resources/virm- ... g-v4a2.pdf
We should really have a sticky to the whole VIRM, given that it can be a bit tricky to find sometimes!
http://www.nzta.govt.nz/resources/virm- ... ation.html
VIRM Section 4-5 wrote:Reasons for rejection
Performance
16. When switched on, a direction indicator lamp:
a) does not operate, or
b) does not begin flashing within one second of
switching on, or
c) flashes:
i. faster than two flashes per second, or
ii. slower than one flash per second, or
iii. at a different rate from other lamps on the same
side.
I want to know if these would be legal?
http://www.youtube.com/watch?v=dTmzfrRU ... re=related
jzs147 Aristo money pit- Mr Revhead
- SECURITY!
- Contact:
Or you could chuck a resistor in there to correct the current draw and make them flash at the correct speed.
Should probably look into the whole park light/indicator situation though.
5w generally is only used for park/rego lamp/instrument cluster and interior lighting.
- Adamal
- Toyspeed Member
Found some of the bulbs I needed in 21w. Only problem was that they only had them in clear, not orange, and I have clear indicators.
No problem, down to the nearest model shop and picked up a small pot of enamel clear orange paint.
I now have proper speed indicators
