rattly cam chain?
Post Reply
Contact:
rattly cam chain?
Post by deaf_rattle »
Is a rattly cam chain something that can be fixed easily? or is it similar deal to replacing a cambelt?
Contact:
Post by Rick »
It is not easier or cheaper than doing a cambelt. This wouldn't happen to be on a SR nissan motor during the first few seconds of start up?
Contact:
Yo
Yeah. Sr motor.was abit rattly when warm.
celica_xr9145
Post by celica_xr9145 »
Got it on my s14 aswell, its probably the common VCT rattle
Contact:
Post by iOnic »
Can be the chain tensioner too. Did it on my S14
Post by Adamal »
Same thing happens on my S14. Only when I first start it up though.
AE82 FXGT
Post by AE82 FXGT »
Common fault on silvias, found the same thing with my 6 MPS, though I knew when I bought it (got my 2.5k off the price).
I'm part way through doing the job and am replacing the chain, tensioner and variable cam, I did find that it was the cam making the noise though.
No harder than a cambelt.
Crucible
Real Life Mechanic
Re: Yo
Post by Crucible »
new_breed wrote:Yeah. Sr motor.was abit rattly when warm.
The SR18/20 nissans have a common problem with the camshaft oilers clogging up, more of a grinding noise than a rattle though...something to keep in mind.
CAMB01
Re: Yo
Post by CAMB01 »
2nded, when i was working as a machinist we used to have the cam oil rails ready to go with slightly larger holes drilled into them, because it was so common. Don't neglect oil changes on Nissan motors.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
Post by rollaholic »
it seems to be mainly the older ones that had that problem
its why when you go to pickas every SR has the rocker cover off and the cams missing, haha
Contact:
went for another s14 in the end. there seems to be abit of a miss at idle.
Changed the plugs. didnt make much difference.
Going to get the timing checked out next and replace the leads.
Post Reply
