What i wanted to know is, is it possible for the fragments from the exhaust wheel to be projected back up the manifold into the engine?
CT26 Exhaust Wheel Gone
- loudstealthGT-Four
- Toyspeed Member
So today my turbo gave up, exhaust wheel went bang
Yes, that's how I blew up my first 450hp CT26 and my 3S-GTE.
was doseing it back in 2001, and a lot of boost
nek minnit....... actually it was more like 3 months later, back to normal boost and BOV, driving home normally and car randomly stalled.
Checked compression: 30, 0, 0, 0 or some shit.
Bores all fuct.
Was doing about 0.5 bar on partial throttle around 4k rpm.
Still have the fuct wheel, looks like someone took all the fins out and you're left with a core.
Bores all fuct.
- Dell'Orto
- ** Moderator **
You'd be unlucky for it to happen - do you still have a cat?
- Toyspeed Member
Akane wrote:Yes, that's how I blew up my first 450hp CT26 and my 3S-GTE.
Bores all fuct.
Yea there is nothing left of my exhaust wheel, it's all MIA.
Reason I ask is that after it happened engine started to knock, sounded like it was coming from up top of the engine, then seems to have gone away after it's cooled down
- Toyspeed Member
- Toyspeed Member
- Toyspeed Member
maybe crazy idea, but could you take the plugs out and twirl a magnet around in each bore before you start it up again? Just in case?
(btw, not sure what the fins are made of...)
- Toyspeed Member
AE82 FXGT wrote:maybe crazy idea, but could you take the plugs out and twirl a magnet around in each bore before you start it up again? Just in case?
I've already driven it for 20mins since it happened, as I had to drive home from my parents house, it was a very very smokey trip home
I had a factory cat on mine, were you boosting while it happened?
I think your engine is toast.
- Toyspeed Member
loudstealthGT-Four wrote:Akane wrote:I had a factory cat on mine, were you boosting while it happened?
Yea was about 3000rpm and 6-8psi
I'm thinking that to, but secretly hoping not
Pretty much the same then.
Compression test next and then buy a real 3S-GTE?
- Luke - BZG
- Toyspeed Member
- Contact:
Re: CT26 Exhaust Wheel Gone
loudstealthGT-Four wrote:So today my turbo gave up, exhaust wheel went bang.
Thats what had happened to my 2JZ-GTE I bought, bores, pistons and head were rooted.
- rollaholic
- Toyspeed Member
ouch man! sorry to hear that!
if your engine is unscathed which i hope it is - there is a CT26 here in the garage - its condition is when we pulled it off "boosts well and smooth, no untoward noise but possibly oil seals are letting oil leak into intake"
if you want it im sure you can have it real cheap given its condition - ill hit up the owner of it if you might be keen to recondition it or something
- Toyspeed Member
