oil coolers - cheap vs. expensive
Not much of a techy question but didnt know where else to put it, is there a hell of a lot of difference between the expensive/branded oil coolers over the cheaper/no- branded ones? just want to know if its worth spending the money on a branded one or if there all pretty much the same and work pretty much the same?
cheers guys
cheers guys
I've been looking into this too. from what I can tell, it's the same arguement as with cheap/expensive intercoolers. Basically they will do the job required... depending on the job required
If you expect to run fairly normal oil pressure, and you want a cooler just for a little peice of mind when on the loud pedal for extended periods, then I see no problem with something less expensive. But if the life of your engine depends on having constantly cooled oil even on a casual milk run, then you may want to spend $700 plus on some fancy Seatrab cooler.
One thing I will say tho... most people seem to complain about cheap "kits" not nessessarily the actual coolers. and most complaints are around leaks from hoses and fittings.. as such a cheap cooler should be fine (povided it's not a coke can with dash fittings
), and just make up your own lines.
Of course this is just what I've gleened from a bit of google research and hearsay from friend @ trackdays etc.. but it is how I intend to approach my car.
I would be interested to hear from those with "actual" experience with oil coolers - cheap and expensive
TA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
- evil_si
- Toyspeed Member
- Contact:
Ive seen metal swarf and rough internal passages on cheaper oil coolers,
Made me very sceptical about the build quality,
I fitted one not so long ago as requested by a customer flushed it out a few times, and definately got contaminants out of it
I personally run a setrab cooler on my rx7, that was spotless inside
I put on a setrab in my supra, the cooler was the cheap bit, the AN fittings cost about the same again. I run a oil thermostat as well as oil filter relocation so there a few extra fittings.
One point to look into is not to get too big a cooler as over cooled oil is no ones friend... hence the water vapor out of my catch can.......
the danger with cheap ones is they could crack at high pressure and temps, the only way you will know this is when you or the people behind you skid out or you loose oil pressure and kill your engine.
Better off going quality and smaller.
Yeah, I'm planning to go the OEM route with mine too. I've got a 300ZX one in the works. Like Looonie said an OEM cooler that lasts hundreds of thousands of kms is more trustworthy than whatever cheap "looks like it works" the Chinese come up with. I say that, and I'm Chinese
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
Looonie wrote:Why would you care?
Just go to Pick A Part and pay $8 for an OEM oil cooler from a Pajero.
Unless you want shiny bling silver bits? I'd put more faith in the Mitsi OEM part than a $300 china kit.
just the sort of knowledge I was hoping to get from this thread.
mine won't be one show so this suits me...
Thank you good sir
- slammed_integral
- Toyspeed Member
just splash out on one morgan
I splashed out back in the day and brought a real deal one cost like $650 for the cooler alone
They have since come down a bit cheaper but i would go for a good quality one, doesnt have to top of the line just a well made one.
You have to keep that black blood pumping around that engine when youve invested that amount of money in it...
Picked up a cheap one looks pretty much the same for $100 but to scared to use it..............as at that price you can guarantee it aint pressure tested or anything
- touge_ae101
- Toyspeed Member
just to offer another perspective i've been rocking a 'cheap' kit from trademe oil cooler + relocation kit and it has worked fine for me so as far as daily driver + racecar duties go. just do regular oil changes and keep a fresh filter on it and its fine. no leaks or defects if you take your time fitting it correctly IMO.
i would probably opt for an rx7 cooler if i were to do it again, but the bit to figure out is fittings etc. also when i was looking they were wanting moonbeans for pretty rough looking coolers (all fins bent etc)
cheers guys, im looking at a few options at the moment but the setrab option is looking pretty good, it is a bit more on the pricey side but like metric said iv put too much money and effort into my setup so far to go cheap and risking it all as oil is the life line of an engine pretty much.
Im planning on pairing it up with a NZKW relocation kit that i purchased a while back, anyone delt with these kits? and if so any probs with leaks etc?
NOLAW wrote:cheers guys, im looking at a few options at the moment but the setrab option is looking pretty good, it is a bit more on the pricey side but like metric said iv put too much money and effort into my setup so far to go cheap and risking it all as oil is the life line of an engine pretty much.
be careful with the cheaper kits , i bought 1 off trademe and it didnt have parallel thread so if you are using it in high pressure situation it may end up blowing off , id recommend Greenlane speed shop , the american one i have is really good quality .
and too have no problemns with leaks use loctite hydraulic thread sealer
The NZKW kit I looked at in the shop felt very cheap compared to real AN fittings, they also had strange threads on the coolers so that only the cheap an fittings that came with the kit would fit them.
They are about 1/3 the cost compared to buying the same items from GSS or somewhere made in the western world.
Thread sealant shouldn't be needed with AN style fittings
limbo wrote:I put on a setrab in my supra, the cooler was the cheap bit, the AN fittings cost about the same again. I run a oil thermostat as well as oil filter relocation so there a few extra fittings.
I've done the same in my Supra also a 19 row Setrab with all the relocation less the thermostat.Only other thing I can add to this make sure the oil cooler is well ducted and has plenty of cold air going over it.
blitza wrote:limbo wrote:One point to look into is not to get too big a cooler as over cooled oil is no ones friend... hence the water vapor out of my catch can.......
ummmmmmmmmmmmm why?
Overcooled oil won't flow as well as oil that's at the right temp,
steroidcontaskie
- Toyspeed Member
I also have a 19 row setrap cooler with GSS AN fittings in my 2j. Fittings and lines cost way more than cooler did, but I guess you don't want a leak.
Dont know if it is any good, as the car is running, but it looks mean. I would think that a thermostat is a good idea, but it can be tricky to get ones in a large size. Took me a while to find a -10AN one.
Science never sleeps...
RVR Turbo (idle)
RVR Turbo (idle)
