Wierd hesitation on Mazda 323 - Sorted, cleaned the AFM
Post Reply
no_8wire
Post by no_8wire »
My girlfriend has a 2000 Mazda Familia wagon 1.5 ZL that is giving weird issues.
Basically the car was stuttering at low speeds and hesitating then taking off once you reached about 4000rpm.
I replaced the filthy air filter and sparkplugs, which seemed to make a difference to the stutttering.
But the car still feels like it is hesitating struggling to breathe/go under 4000rpm. It has no go or power (even for a 1.5L) but once you reach over the threshold, it picks up and flys in comparison.
Even when the car is stationary and you rev it the car will not freely rev until over 4000rpm. Even with no load it is sluggish and hesitant in how it revs at low rpm.
Any ideas on what I could check?
Its got me stumped at the moment...because it is also somewhat intermittent.
wde_bdy
Contact:
Post by wde_bdy »
Try cleaning AFM, was a temporary fix on my 1500 Demio. I have two so was able to troubleshoot by swapping parts, had very similar symptoms.
Callum
no_8wire
Post by no_8wire »
The wire with a orange glob on the end on the left of the photo?
I cleaned that softly with carb cleaner and an very small piece of cotton wool.
Do you need to clean up the larger tube as well on the right)?
wde_bdy
Contact:
Post by wde_bdy »
Don't think mine looked like that, I just sprayed it full of AFM cleaner from Repco. Was only a temporary fix and I ended up getting a new AFM.
Callum
Post by sergei »
no_8wire wrote:The wire with a orange glob on the end on the left of the photo?
The orange blob is just a thermistor (temp sensor), the real guts are inside of the black tube: you can see it usually covered in crap if you look inside.
no_8wire
Post by no_8wire »
Sweet, I will give the insides a good clean and see if that make a difference.
B_giB
Post by B_giB »
The little wire in side is VERY thin, do not touch it with anything, just spray and walk away!
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
no_8wire
Post by no_8wire »
Spray from a safe distance, a few short bursts a couple of times rather than a hard long blast... I believe that is the accepted way to do it without damage?
B_giB
Post by B_giB »
Correct!
BZG Wagon
Post by BZG Wagon »
There's a thread I have on another forum outlining what happened to my GF's car, plus how I diagnosed it:
http://www.amazd.co.nz/forum/viewtopic.php?f=2&t=19725
Could be of help.
no_8wire
Post by no_8wire »
Cleaning the afm sorted it... amazing how much difference it makes to driving the car.
Will keep an eye on it to see it if happens again and need to replace the afm, but hopefully it has sorted the issue
Post Reply
